RC Perspective 509 Posted July 5, 2022 Part of the reason I retired the body was because of how wide it is. I used like 10-15mm hex adaptors, but the 15mm required those extended nuts and I didn't like running those at high speed. I wound up running BSR Racing 32mm Foams. They're deep and extra wide for grip. Anything over 60mph and you'll want foams anyway. The rubber tires, unless belted, will start to deform at these speeds. For this body, the deeper the offset on the wheels, the less thickness of hex spacers you'll need. I think starting with a -8 or -10 offset wheel will get you pretty close. You want deep rims for this one. Now that I think about it, the deep 32mm Tamiya 2 piece wheels would probably work great for this body, but you'd need 4 rears and they can be hard to find. It actually looks better than I thought in white. I think the Millennium Jade one also looks good. -RC Perspective Share this post Link to post Share on other sites
Ducky177 3 Posted July 5, 2022 21 hours ago, RC Perspective said: Part of the reason I retired the body was because of how wide it is. I used like 10-15mm hex adaptors, but the 15mm required those extended nuts and I didn't like running those at high speed. I wound up running BSR Racing 32mm Foams. They're deep and extra wide for grip. Anything over 60mph and you'll want foams anyway. The rubber tires, unless belted, will start to deform at these speeds. For this body, the deeper the offset on the wheels, the less thickness of hex spacers you'll need. I think starting with a -8 or -10 offset wheel will get you pretty close. You want deep rims for this one. Now that I think about it, the deep 32mm Tamiya 2 piece wheels would probably work great for this body, but you'd need 4 rears and they can be hard to find. It actually looks better than I thought in white. I think the Millennium Jade one also looks good. -RC Perspective I'm currently running the stock hex adapters with 26mm wide/61 diameter wheels that has 3mm offset and in my opinion the fitment is basically perfect. Except for that the wheels look a bit small. Share this post Link to post Share on other sites
Ducky177 3 Posted July 5, 2022 10 hours ago, RC Perspective said: Part of the reason I retired the body was because of how wide it is. I used like 10-15mm hex adaptors, but the 15mm required those extended nuts and I didn't like running those at high speed. I wound up running BSR Racing 32mm Foams. They're deep and extra wide for grip. Anything over 60mph and you'll want foams anyway. The rubber tires, unless belted, will start to deform at these speeds. For this body, the deeper the offset on the wheels, the less thickness of hex spacers you'll need. I think starting with a -8 or -10 offset wheel will get you pretty close. You want deep rims for this one. Now that I think about it, the deep 32mm Tamiya 2 piece wheels would probably work great for this body, but you'd need 4 rears and they can be hard to find. It actually looks better than I thought in white. I think the Millennium Jade one also looks good. -RC Perspective And what wheel diameter did u use? (Sorry for all the questions) Share this post Link to post Share on other sites
RC Perspective 509 Posted July 6, 2022 13 hours ago, Ducky177 said: And what wheel diameter did u use? (Sorry for all the questions) Standard 1:10 touring car wheels. Those wheels you have look to be much more than a -3 offset. But that seems to be an issue with aftermarket wheels; some of them don't list the correct offset. -RC Perspective Share this post Link to post Share on other sites
Ducky177 3 Posted July 6, 2022 1 hour ago, RC Perspective said: Standard 1:10 touring car wheels. Those wheels you have look to be much more than a -3 offset. But that seems to be an issue with aftermarket wheels; some of them don't list the correct offset. -RC Perspective Ok, yeah I thought so too because they sit much wider on the car than 3mm more than my stock ones with no offset. Thank you so much for all the help you have been giving me. 1 Share this post Link to post Share on other sites
RC Perspective 509 Posted July 6, 2022 2 minutes ago, Ducky177 said: Ok, yeah I thought so too because they sit much wider on the car than 3mm more than my stock ones with no offset. Thank you so much for all the help you have been giving me. No problem bud! -RC Perspective Share this post Link to post Share on other sites
Ducky177 3 Posted July 15, 2022 On 7/6/2022 at 3:43 PM, RC Perspective said: No problem bud! -RC Perspective Little update! I made a "drag spoiler" and a roof spoiler out of sheet metal. (Very thin so not that heavy.) I've been running it with 70% throttle and that's basically the perfect speed for street bashing. I ran 100% one time and blew a set of tires. (But they were old so I'm not so surprised) Did some big and fast barrel rolls so I had to use "the duct tape of the rc world" (zip ties) to fix the front lip and rear bumper. But from that everything is working perfectly! I'm so happy with my tt02! Thanks for helping me Rc perspective! You are the best! 1 Share this post Link to post Share on other sites
RC Perspective 509 Posted July 16, 2022 On 7/15/2022 at 2:46 PM, Ducky177 said: Little update! I made a "drag spoiler" and a roof spoiler out of sheet metal. (Very thin so not that heavy.) I've been running it with 70% throttle and that's basically the perfect speed for street bashing. I ran 100% one time and blew a set of tires. (But they were old so I'm not so surprised) Did some big and fast barrel rolls so I had to use "the duct tape of the rc world" (zip ties) to fix the front lip and rear bumper. But from that everything is working perfectly! I'm so happy with my tt02! Thanks for helping me Rc perspective! You are the best! Happy to help bubba. I remember when I first drove mine; what a rush! -RC Perspective 1 Share this post Link to post Share on other sites
