On 11/7/2023 at 1:10 AM, GeeWings said:
Wow! What a lovely collection. These three in particular have me drooling! 😜
Thanks! Glad you liked them!
21 minutes ago, BuggyDad said:
This is just utterly marvellous.
Thanks, I appreciate that!  The build is all very "goofy", so it seemed like a fun touch.  :)
On 11/17/2023 at 3:17 AM, bRIBEGuy said:
I’ve said it in another thread but this whole build is so good. Love all the personal touches you’ve added and the co-drivers manual is just 🤩
On 11/17/2023 at 5:40 PM, OoALEJOoO said:
Another WOW! Where did this beauty suddenly come from? Absolutely perfect!
Thank you, my friend! Slowly going through my backlog of spare bodies. Right now it's mounted on a trusty TT-02 but, given the real Porsche RSR is RWD, I am contemplating yet another RWD conversion. This classic RSR had a rear-engine (unlike the contemporary RSR which is mid-engine), and therefore the best way to reflect this is to do the following conversion: MF-01X + TL-01 arms + 254mm (or 249mm) wheelbase, without the need of extending the propeller shaft since its RWD.
Ended up going with a Savox 1251MG servo.
Anyone building one of these, I recommend a low profile servo - if the manufacturer’s dimensions are even slightly out (for a full height servo), then it likely won’t fit.
@_Ben_: My first thoughts, „wow…cool black TRF201 mod and how did he get all these parts black?“😂
Presumably because I have in my TRF201 the same servo:
But this is a Kyosho Dirt Master, isn‘t it?
Correct - it’s a Dirt Master!
What is Tamiya designed The Frog to have a beetle body?
I bought a couple of Sand Scorcher bodies last year with the intention of using one for the SRB pile-o-parts and one extra. At some point I put the SRB on the back burner and thought I’d use one on the Frog. After looking around for inspiration, I found a lot of stock Sand Scorcher paint schemes. Then I thought of the Frog livery on a beetle body. Also added the spot light pods from the Frog to try to carry the look over. I’m happy with the results, but not sure I’ll keep it.
@ADRay1000 - how did you fit the Sand Scorcher body to the ORV (Frog) chassis? Front is the standard pin, I guess, but on the sides? Just screws into the battery holder on each side?
yes for the sides, and a stock Brat post for the front. I’d like to come up with something better. I’ve seen people make roll bars that use the sand scorcher mounting point that I might try to replicate.
4 hours ago, Toolmaker72 said:
Built a few of the scorcher on frog chassis.   I found the front sits a little too high unless you shape it around the  radius arms on the front suspension.
 Yeah, it rides a little high in the front. Someday I’d like to look into an aftermarket shock and shock tower setup that might need that space. Or I’ll shorten the Brat post 😬
42 minutes ago, Xeostar said:
Wow mate!!!😯 That is epic😎 It's all paint again as usual I assume?
I know you usually do out of the ordinary designs, so what is this colour scheme? It's so nuts it works!!!👍👍
@Kol__ Thanks :D, I'm quite pleased with it, probably my best one yet I think.
Yes 95+% paint, things like the headlights and rear light cluster are the decals but all the Porsche, Ansys and Penske are painted as are all the colours and the black and white stripes between them.
I'd like to say it's my original design but it's a copy, sort of, from the 100th Le Mans, Porsche 936 Penske Motorsport livery. I really like it so attempted it.
HELLER cooperates with Porsche Penske Motorsport
