Pylon80 4226 Posted July 13, 2022 I thought I would share quickly my latest TT-02 iteration. The idea was to have a fully adjustable chassis that uses standard - rather than type S - TT-02 parts. Also I wanted to make sure the original parts would not require complex modifications and that the number of custom parts would be reduced to an absolute minimum. The result is also mechanically "clean" in that there is no unwanted change in caster as the suspension compress. The extra holes on the plate allow adjusting roll center when using type-S shock towers. So here it is! I am quite happy with how it turned out. I can now dial in camber, caster, bump steer and Ackerman. 9 Share this post Link to post Share on other sites
TurnipJF 10812 Posted July 13, 2022 Looking very neat and tidy! 2 Share this post Link to post Share on other sites
RC Perspective 527 Posted July 13, 2022 Nice! I've been using the forward facing links for Caster and the whole adjustable arm for camber. No top plate needed for the front. Can alter the angle depending on the ride height with spacers/threaded posts. A slop free front end on a TT02 is nice I'm also a big fan of the Type-S steering set. I've got it on the R above too. -RC Perspective Share this post Link to post Share on other sites
Pylon80 4226 Posted July 13, 2022 19 minutes ago, RC Perspective said: Nice! I've been using the forward facing links for Caster and the whole adjustable arm for camber. No top plate needed for the front. Can alter the angle depending on the ride height with spacers/threaded posts. A slop free front end on a TT02 is nice I'm also a big fan of the Type-S steering set. I've got it on the R above too. -RC Perspective I saw TT-02's with forward facing links on RCTech a couple years ago. It's an easier route but caster will change as the suspension compresses. This is because the attachment points on the bumper are not at the same width as the attachment points of the camber links. That won't stop the car from driving well. In fact this is sometimes a compromise that even Tamiya makes: the F104 F1 chassis are like that for example. But I wanted to get the cleanest kinematics that I could. 1 Share this post Link to post Share on other sites
RC Perspective 527 Posted July 13, 2022 18 minutes ago, Pylon80 said: I saw TT-02's with forward facing links on RCTech a couple years ago. It's an easier route but caster will change as the suspension compresses. This is because the attachment points on the bumper are not at the same width as the attachment points of the camber links. That won't stop the car from driving well. In fact this is sometimes a compromise that even Tamiya makes: the F104 F1 chassis are like that for example. But I wanted to get the cleanest kinematics that I could. Sounds about right. On the setup station after adding the Mini CVA's and setting the ride height high with the hubs, then dropping it down a little via shock position, I was able to achieve no appreciable caster change on suspension compression/rebound by setting the links to a neutral position at ride height, and slightly stiffer springs to limit the travel range. In order to change the caster, I'd have to be going fast enough to flip when turning. I'm not racing it, but speed running/general bashing, So I doubt I'd really notice any difference between the two setups. The compression and rebound caster change could be manipulated to an advantage If I'm thinking about it correctly. Almost like a reactive camber setup, but with caster instead. Either way though, it really cleans up the front suspension slop. I may be able to use your design on my drifter, As the front attachment point is blocked because I moved the upper shock portion to the body post location. The Square Drift steering needs some slop removal. Could also mount the Gyro on it too! -RC Perspective Share this post Link to post Share on other sites
Pylon80 4226 Posted July 13, 2022 37 minutes ago, RC Perspective said: The compression and rebound caster change could be manipulated to an advantage If I'm thinking about it correctly. Almost like a reactive camber setup, but with caster instead. You got that exactly right. I am happy to share the file if that helps. I had the plate cut by Fibre-lite but haven't put it on their website as I didn't want to interfere with the outstanding work that our friend @qatmixhas done already. 1 Share this post Link to post Share on other sites
RC Perspective 527 Posted July 13, 2022 Just now, Pylon80 said: You got that exactly right. I am happy to share the file if that helps. I had the plate cut by Fibre-lite but haven't put it on their website as I didn't want to interfere with the outstanding work that our friend @qatmixhas done already. Good to know the suspension theory stuck in my head That would be awesome! @qatmix Has put in some incredible work! Though I don't think he would mind as that's what the community is about; Sharing knowledge and progress. I certainly don't speak for him, but same goes for the Aero stuff I've been designing; it's Public Domain Dedication as I would love to see others expand on the chassis/body combos I have already covered. As a collective, the community can design things that would only be rivalled by major companies. One of the reasons I absolutely love the onset of 3D printing. -RC Perspective 2 Share this post Link to post Share on other sites
twaleta 161 Posted June 22, 2023 On 7/13/2022 at 9:36 AM, Pylon80 said: Share this post Link to post Share on other sites
twaleta 161 Posted June 22, 2023 On 7/13/2022 at 9:10 AM, RC Perspective said: Nice! I've been using the forward facing links for Caster and the whole adjustable arm for camber. No top plate needed for the front. Can alter the angle depending on the ride height with spacers/threaded posts. A slop free front end on a TT02 is nice I'm also a big fan of the Type-S steering set. I've got it on the R above too. -RC Perspective Looks nice! do you have the sizes or lengths for the screws/turnbuckles (and also the plastic spacers on the bumper and the ball nut thingies the turnbuckles connect to?) Im using stock bumper Share this post Link to post Share on other sites
skom25 2389 Posted February 27, 2024 On 7/13/2022 at 3:35 AM, Pylon80 said: I thought I would share quickly my latest TT-02 iteration. The idea was to have a fully adjustable chassis that uses standard - rather than type S - TT-02 parts. Also I wanted to make sure the original parts would not require complex modifications and that the number of custom parts would be reduced to an absolute minimum. The result is also mechanically "clean" in that there is no unwanted change in caster as the suspension compress. The extra holes on the plate allow adjusting roll center when using type-S shock towers. So here it is! I am quite happy with how it turned out. I can now dial in camber, caster, bump steer and Ackerman. It was long time ago, but maybe you remember. To adjust camber, you used standard ball nut and M3 screw. Hole for suspension arm has 5 mm. Which part you used as an adapter? Share this post Link to post Share on other sites
Pylon80 4226 Posted February 27, 2024 6 hours ago, skom25 said: It was long time ago, but maybe you remember. To adjust camber, you used standard ball nut and M3 screw. Hole for suspension arm has 5 mm. Which part you used as an adapter? Oh I still have that car actually! To make the adapter I used a piece of aluminum standoff cut I the right length (search "M3 rc drone aluminum standoff" on eBay). It was exactly 5mm diameter. I slipped it on an M3 screw. The screw was a countersunk one (flat head) with an aluminum dimple washer. I really need to make a build thread for it one day. There's a lot of interest in the TT-02. 2 Share this post Link to post Share on other sites
