Svlreclame 280 Posted August 30, 2022 I am painting a Globeliner Bodykit. Masking the lines for the stripes Painting the stripes The top stripe colour is a dark grey that has a orange sparkle effect through it, the other stripe is a shadeshifter, that changes from pink to orange to green to orange. In the top stripe there is only the orange sparkle that can also be found in the lower stripe. The thin outline is a dark grey metallic with a violett effect in it. The main body colour is a Black Cherry colour. After sanding and polishing the fenders. 11 Share this post Link to post Share on other sites
Kevin_Mc 411 Posted August 30, 2022 Wow! That looks incredible Share this post Link to post Share on other sites
MadInventor 3884 Posted August 30, 2022 Looks fantastic, and like many, many hours of work. Share this post Link to post Share on other sites
bRIBEGuy 3049 Posted August 30, 2022 I wish I never found this thread... now I want to go home and throw out anything I've ever painted! That cab looks amazing. Well done! 1 2 Share this post Link to post Share on other sites
Re-Bugged 10156 Posted August 31, 2022 That is some serious quality workmanship, excellent job 👍🏻 Share this post Link to post Share on other sites
Beetlemankurt 676 Posted September 1, 2022 Top job! Looks fantastic and great colour choice. What sort of masking tape did you use to get the tight corner curves and nice clean crisp edges? Cheers Kurt Share this post Link to post Share on other sites
Svlreclame 280 Posted September 1, 2022 I have 25 years of experience with installing vinyl decals, never took a shortcut to figure out how to do something. Share this post Link to post Share on other sites
Beetlemankurt 676 Posted September 1, 2022 Hi, perhaps you misunderstood my question?...I'm not asking for a shortcut,.... I am simply interested in the masking material/tape you used as you have done a very nice job here. I would politely suggest that perhaps your 25 years experience could be used to help others on this forum including myself, if you are willing to share your tips. If not, no problem, I'll keep happily using my Tamiya masking tape 😎..... Kurt 1 Share this post Link to post Share on other sites
Svlreclame 280 Posted September 1, 2022 That is what i use too.... i did not mean it in a bad way. What i meant to say is that practice makes perfect. Some things take time to master, only tons of practice can take it to this level. Do it, look at what went wrong, then fix it and do it again. I do not have a magic trick to get it on. I did however chew through lots of masking tape to learn it. And if i did not like the result i pull it all off and do it again, untill i like it. You will get better with each roll you use. I remember the first time i used the masking tape... i thought i was going mad.... did not get great results at all, but kept redoing it till i got good at it. My first curves were horrible, and that was on a real car, not even a scale model. With everything i do i keep searching for the limits of what a material can and cant do, i like to figure out stuff that most run away from. Only advice i can give is get a box of tape and practice. 2 Share this post Link to post Share on other sites
Beetlemankurt 676 Posted September 1, 2022 @Svlreclame, thanks for the reply and good advice. Good to hear that the Tamiya masking tape is up to the task, I've always found it to be pretty darn good. I've got a paint job to do in the coming months on my Kenworth which has some very thin lines/stripes on it so you've given me some extra confidence here. Thanks again. Kurt Share this post Link to post Share on other sites
backtomyroots 432 Posted September 1, 2022 Well, that's about the best looking Globe Liner I've ever seen. Share this post Link to post Share on other sites
Svlreclame 280 Posted September 5, 2022 Here comes the shine.... 1 Share this post Link to post Share on other sites
Beetlemankurt 676 Posted September 5, 2022 That's impressive! Very nice work. Cheers Kurt Share this post Link to post Share on other sites
