I picked up a job lot of crystals to use with my old 27MHz Acoms Techniplus radio gear. I tested them and they all worked as expected. They were in need of new labels, so I printed some up. When I took the old labels off, the frequencies printed on the metal casing were as expected for all of the transmitter crystals, but for three of the receiver crystals the frequencies printed on the metal casing were different to the frequency marked on the labels, and the printed frequencies were not ones I was familiar with. See table below:
Channel
Colour
Expected Frequency
Marked Frequency
1
Brown
26.995
26.540
2
Red
27.045
26.590
5
Green
27.195
26.740
The job lot also included some crystals without labels, with frequencies printed on the casings that I'm not familiar with. They are:
  • Tx 26.690 and Rx 26.690
  • Rx 26.800
  • Rx 27.175
Does anyone know what's going on here?
Ok I figured it out. I noticed that the difference is always 0.445MHz, and when I googled that I found an article that said that receiver frequencies are always 0.445MHz lower than the transmitter frequency (it didn’t say why though), and that different manufacturers label them in different ways.
That solved everything except the 27.175MHz crystal which I’m happy to leave as a mystery
You got to the bottom of the frequency offset on the RX crystals. They aren't always marked that way.
27.175 would be a yellow/green "split" crystal as alluded to above.
  • 2 months later...
Sold a full set of splits a while back, and just found the pic I took for ebay.
(Actually bought these, when I got back into RC ,and went to run at a club with my Futaba Attack R. Some looked confused, when I asked about the 'peg board'.....🙄🤣)
20200214_111155
20200214_111148
As above, yellow/green split.
