wilysloth 22 Posted September 5, 2022 It seems to be recommended whilst building the XV-01 to replace the NN4 part in step 2 with an alloy version (to protect the BG1 gear). Does anyone have a suggestion where I might buy an alloy replacement? I have seen the SSD00151 part suggested but cannot find it or an equivalent in the UK. Are the dimensions of the stock NN4 part: OD 7.2mm, ID 4mm, thickness 1.5mm? If I fail to find one, how might continuing to use the stock NN4 part but with added M4 alloy shims on either side fare? Share this post Link to post Share on other sites
Juhunio 6830 Posted September 5, 2022 @wilysloth I haven't built mine yet, but when I do I have these Eagle Racing parts to replace the NN4 spacers Might be worth seeing if you can track some down? 2 Share this post Link to post Share on other sites
qatmix 794 Posted September 5, 2022 The kit part is perfectly fine. I've been running (Bashing) my XV01 with a 10.5 brushless (No boost). Since it was available and the gearbox is still perfect. 3 Share this post Link to post Share on other sites
Big Jon 684 Posted September 6, 2022 20 hours ago, qatmix said: The kit part is perfectly fine. I've been running (Bashing) my XV01 with a 10.5 brushless (No boost). Since it was available and the gearbox is still perfect. I’ve got to disagree. I had a failure years ago, and replaced the spacer with the SSD spacer; have not had a failure since. Many of the XV-01s in our club have had the same issue with heavy use. An aluminum spacer solves the problem permanently. The SSD spacer doesn’t show as discontinued, but hasn’t been available in a while, so finding a correct spacer has been difficult. 3 Share this post Link to post Share on other sites
Big Jon 684 Posted September 6, 2022 On 9/5/2022 at 11:13 AM, qatmix said: The kit part is perfectly fine. I've been running (Bashing) my XV01 with a 10.5 brushless (No boost). Since it was available and the gearbox is still perfect. I’ve got to disagree. I had a failure years ago, and replaced the spacer with the SSD spacer; have not had a failure since. Many of the XV-01s in our club have had the same issue with heavy use. An aluminum spacer solves the problem permanently. The SSD spacer doesn’t show as discontinued, but hasn’t been available in a while, so finding a correct spacer has been difficult. 1 Share this post Link to post Share on other sites
Nicadraus 6201 Posted September 6, 2022 4 hours ago, Big Jon said: I’ve got to disagree. I had a failure years ago, and replaced the spacer with the SSD spacer; have not had a failure since. Many of the XV-01s in our club have had the same issue with heavy use. An aluminum spacer solves the problem permanently. Agreed! Almost every XV-01 owner has had this issue even on the FB page. The stock plastic spacer causes the pin to eat up the gear. The aluminum spacer (and some shims) solves the issue. 4 Share this post Link to post Share on other sites
Juhunio 6830 Posted September 6, 2022 The black Eagle Racing spacers seem to still be available in a couple of places 👍 Share this post Link to post Share on other sites
smirk-racing 253 Posted September 15, 2022 On 9/5/2022 at 8:30 AM, wilysloth said: Are the dimensions of the stock NN4 part: OD 7.2mm, ID 4mm, thickness 1.5mm? No. The stock part measures 6x4x2mm (OD, ID, thickness). Share this post Link to post Share on other sites
wilysloth 22 Posted September 15, 2022 2 hours ago, smirk-racing said: No. The stock part measures 6x4x2mm (OD, ID, thickness). Thank you @smirk-racing I just need to find somewhere that stocks the Eagle Racing part that will ship to the UK now. Share this post Link to post Share on other sites
wilysloth 22 Posted September 15, 2022 These Square SGE-120 parts are also exactly right but shipping to the UK is many times the cost of the part. But might be useful for someone in the EU. As for me, still looking. Share this post Link to post Share on other sites
wilysloth 22 Posted September 15, 2022 Postage still not ideal but ended up ordering the Eagle Racing part from here. Thanks @Juhunio 1 Share this post Link to post Share on other sites
BuggyGuy 1106 Posted September 15, 2022 This looks like it would do the job https://www.servocity.eu/p/1502-series-4mm-id-spacer-6mm-od-2mm-length-4-pack/ Or 4 of these: https://www.rcbearings.co.uk/index.php?route=product/product&path=179&product_id=2000 Share this post Link to post Share on other sites
smirk-racing 253 Posted September 15, 2022 McMaster Carr also has spacers: https://www.mcmaster.com/aluminum-spacers/aluminum-unthreaded-spacers/system-of-measurement~metric/ And there are cheaper ones (also easier to order!) here for folks in the US: https://www.gobilda.com/1502-series-4mm-id-spacer-6mm-od-2mm-length-4-pack/ Share this post Link to post Share on other sites
tamiya3speed 464 Posted September 15, 2022 9 hours ago, BuggyGuy said: This looks like it would do the job https://www.servocity.eu/p/1502-series-4mm-id-spacer-6mm-od-2mm-length-4-pack/ Funny story on this, got up at 4am this morning and couldn’t sleep. I ended up seeing this post and going on a hunt myself. Found Servo City here in the US and put the order in then. Will see how it goes but already got a shipping notice and tracking number so at least they move quick. Share this post Link to post Share on other sites
wilysloth 22 Posted September 16, 2022 23 hours ago, wilysloth said: Postage still not ideal but ended up ordering the Eagle Racing part from here. Thanks @Juhunio Received an email this morning, unfortunately they no longer ship to the UK via airmail so an extra $22.50 is required on top of the original postage. Which for a $2.24 part is just too much. Order has been cancelled. Argh! The hunt goes on. 1 Share this post Link to post Share on other sites
Tamiyastef 1968 Posted September 17, 2022 My LHS has a lot of rc boat builders as customers and so stock a wide variety of round bars, square bars, and also tubes in various materials and sizes. I presume you can saw of a 2mm part of a 6mm outer and 4mm inner diameter tube. Must be cheaper than those rates for postage Share this post Link to post Share on other sites
Juhunio 6830 Posted September 17, 2022 On 9/16/2022 at 10:09 AM, wilysloth said: Received an email this morning, unfortunately they no longer ship to the UK via airmail so an extra $22.50 is required on top of the original postage. Which for a $2.24 part is just too much. Order has been cancelled. Argh! The hunt goes on. That’s frustrating, can you find a few other items at Kleinkram to justify the shipping of the Square RC parts? Share this post Link to post Share on other sites
wilysloth 22 Posted September 20, 2022 So have taken a punt on this part from ebay and will report back if it arrives. With any luck it will be suitable. Share this post Link to post Share on other sites
foz75 93 Posted September 23, 2022 ebay part number 284555643404 looks like it would work (m4 x 6 x 1mm spacers), pack of 10 for £3.49 posted, or 25 for less than a fiver Share this post Link to post Share on other sites
skom25 1245 Posted October 20, 2023 Sorry for a post in a bit old topic. Will it not be enough to just fit thin metal spacer between NN4 and pin? I am sure that I will not be able to find alu replacement in my area. Share this post Link to post Share on other sites
davidwj95 152 Posted October 20, 2023 1 hour ago, skom25 said: Sorry for a post in a bit old topic. Will it not be enough to just fit thin metal spacer between NN4 and pin? I am sure that I will not be able to find alu replacement in my area. That's what I did when i built mine a couple of years ago, there's a YouTube video somewhere that suggests this which is why I did it. I can't really comment how well it works as mine hase only been used about 10 times and only has the kit motor but no problems so far. 1 Share this post Link to post Share on other sites
bavee 1032 Posted October 21, 2023 RC-Kleinkram has suitable spacers in stock: https://www.rc-kleinkram.de/en/square-sge-120-alloy-spacer-4x6x20mm-light-blue-6-pieces But my guess is shimming out the standard parts will also work. 1 Share this post Link to post Share on other sites
wilysloth 22 Posted October 22, 2023 On 9/20/2022 at 3:26 PM, wilysloth said: So have taken a punt on this part from ebay and will report back if it arrives. With any luck it will be suitable. For completeness, the part above was bang on. 1 1 Share this post Link to post Share on other sites
Sogogi 3217 Posted November 23, 2023 On 9/15/2022 at 8:02 AM, smirk-racing said: McMaster Carr also has spacers: https://www.mcmaster.com/aluminum-spacers/aluminum-unthreaded-spacers/system-of-measurement~metric/ And there are cheaper ones (also easier to order!) here for folks in the US: https://www.gobilda.com/1502-series-4mm-id-spacer-6mm-od-2mm-length-4-pack/ Ordered some from gobilda! Share this post Link to post Share on other sites
chris.alex 534 Posted November 23, 2023 Yesterday, when I was looking for other small parts, I stumbled across these metal spacers. I think it's just the right part as a replacement for NN4. https://www.modellbau-seidel.de/index.php?firma=Tamiya&best=2750106 When I built my XV01 I just shimmed NN4 like it was already mentioned by someone else, and haven't had any issues with it. But since this is an original Tamiya part, it might be interesting for those of you who like to use original parts only. However, I don't know if they also ship abroad. 1 Share this post Link to post Share on other sites
