wilysloth 22 Posted September 13, 2022 I have a spare Tamiya 10.5t motor (54611) that I would like to install in an XV-01. Tamiya's guideline for using this motor on a buggy is that the final gear ratio should lie somewhere between 8.9 and 11.7. I assume 8.9 would be suitable for a lightweight 2WD buggy and 11.7 suitable for heavier 4WD buggy. For the XV-01, somewhere in the middle would seem appropriate perhaps edging closer to 11 to keep the temperatures down. Regardless, I would like scope to adjust up and down to find a ratio that works for me. The XV-01 supports pinions from 21T (8.42) to 29T (6.10), ratios outside the recommended range for the Tamiya 10.5t motor with the standard 68T spur gear. So ideally I would like to replace the spur gear with a 102T variant such that the “middle” XV-01 pinion 25T gives a final ratio (10.6) close to the middle of the motor's recommended range. To this end, can I use this Tamiya (54227) FF03 04 Module 102T Spur Gear and this Tamiya (53103) 0.4 Steel Pinion in the XV-01? Perhaps using the Tamiya (54234) FF03 Aluminium Spur Gear Mount. And finally, is my reasoning sound? Share this post Link to post Share on other sites
alvinlwh 5895 Posted September 13, 2022 As always, start on the lower end (bigger number), monitor the temperature and work your way up. There is no real right or wrong answer. On my very first brushless, I started at the safest end and finished beyond the highest recommended as it still ran cool at the top gearing so I went over. But this, of course, depends on your driving surface, etc... Yes, that spur set is listed as suitable but I believe (although I don't own a VX) you can use any spur gears as long as the holes line up. Double check on this as I once cross threaded the equivalent of JJ11 on mine by screwing in the wrong style of spur and had to get a replacement piece. Share this post Link to post Share on other sites
Honza 937 Posted September 13, 2022 You can go for the faster ratio - XV01 has smaller wheels than buggy, effectively reducing speed and load. If you intend to drive on dirt, I would recommend gears with larger teeth, 48p or m0.6. XV uses standard gear mount, so any spur that supports four hole mounts will fit. Share this post Link to post Share on other sites
Nicadraus 6201 Posted September 14, 2022 I have replaced the spur (77t) and pinion (26t) to true 48p. Feels and sounds smoother than the stock ones. Share this post Link to post Share on other sites
Honza 937 Posted September 15, 2022 17 hours ago, Nicadraus said: true 48p. There's fake 48p? 2 Share this post Link to post Share on other sites
wilysloth 22 Posted September 15, 2022 On 9/13/2022 at 8:28 PM, Honza said: You can go for the faster ratio - XV01 has smaller wheels than buggy, effectively reducing speed and load. If you intend to drive on dirt, I would recommend gears with larger teeth, 48p or m0.6. XV uses standard gear mount, so any spur that supports four hole mounts will fit. I hadn't considered the smaller wheels - thank you. My plan is to follow @alvinlwh 's advice and start conservatively and then gear up. I'm pleased to hear that the Tamiya (54227) FF03 04 Module 102T Spur Gear and Tamiya (53103) 0.4 Steel Pinion will fit in the XV-01 and they are both inexpensive so will probably start there even if I end up back with the stock spur and pinion. Hoping to avoid an ESC fan if possible. 1 Share this post Link to post Share on other sites
alvinlwh 5895 Posted September 15, 2022 6 hours ago, Honza said: There's fake 48p? There actually are. Some 0.6mod are listed as 48dp (or the other way round). Share this post Link to post Share on other sites
Honza 937 Posted September 15, 2022 9 minutes ago, alvinlwh said: There actually are. Some 0.6mod are listed as 48dp (or the other way round). I heard about that, but that's not fake 48dp, that's just wrong. If anything could be called fake 48p, it's m0.5, which Tamiya for some reason used on DF03, but 0.6 is more like 42dp - I think that Traxxas sometimes lists its pinions like that. Share this post Link to post Share on other sites
Nicadraus 6201 Posted September 15, 2022 2 hours ago, Honza said: I heard about that, but that's not fake 48dp, that's just wrong. If anything could be called fake 48p, it's m0.5, which Tamiya for some reason used on DF03, but 0.6 is more like 42dp - I think that Traxxas sometimes lists its pinions like that. So there's the answer to your question. Share this post Link to post Share on other sites
Raman36 1656 Posted September 24, 2022 On 9/15/2022 at 7:14 AM, alvinlwh said: There actually are. Some 0.6mod are listed as 48dp (or the other way round). Mod 0.6 is sometimes referred to as metric 48p. This is what they’re referring to as fake 48p, because they’re not compatible with 48p. Im taking a risk by writing this year as some TC memeber will surely have a meltdown that I wrote metric 48. 🤣 Share this post Link to post Share on other sites
