I've got one of those cheap blue ebay esc and it came without instructions.
After a bit of research, 10BL120 set up procedure was mentioned numerous times.
May I suggest just following 10BL120 set up procedure and see what happens.
At the end of the day, you won't damage it and maybe you will have a functioning esc.
2 minutes ago, alvinlwh said:
Oh yes, it is either the LED one or LCD one (which I think you also have?).
It’s the one with the 8 segment LED I have on the kitchen counter and yeah, I also have the LCD one somewhere. Take yer pick!;)
On 9/17/2022 at 12:11 AM, alvinlwh said:
I believe that this is a rebadged Hobbywing ESC of some kind. The USB or card programmer for it is sold out unfortunately. I believe a Hobbywing programmer can also work for it but not sure which one. Any ideas anyone?
I've heard a few people rave about these escs.
Seemingly, you can 'flash them with the hobbywing firmware, and they're awesome...
https://m.facebook.com/groups/143755283082972/permalink/958847318240427/?comment_id=958897991568693
Had a quick look on YouTube, and, looks the LCD one :-
Never really looked too much into it, but , £25 for an esc, flash with hobbywing firmware, giving real boost & turbo options,  so actually better than the 10bl120?!?! 🤯
It depends what firmware has been flashed to it. I have a selection of programmers and usually have to try a few. I have ex run, hobbyking etc. Not as obvious as you might think.
