WRC / RALLY Builds thread
A dedicated thread for all things rally / hillclimb - Motorsport inspired builds that are not on a permanent track.
I’ll start off with the environment context that made me want to start.
Project Start: 2021/01
Tamiya TRF417X - 42205
Ambitions  -
Full LED lighting & make a rally chassis!
Welcome to Sweden!
For the chassis I’m going with a TRF417X. I always liked onroad TRF so I’ve collected a few over the years. I figured I can make an excellent handling and bulletproof chassis more “rally” instead of hop-ing up a plastic chassis with essentially self tapping wood screws to withstand power or terrain.
I much more enjoy working with quality hex hardware and a completely open layout chassis from the get go.
First task was to get some more suspension travel and chassis clearance to the ground. I sanded out the arms and c hubs to allow more droop, added longer damper eye ends, longer springs from the trf201, and protective sleeves over the dampers.
For electrics I went with a Hobbywing 6,5 combo, pretty insane but the TRF is good for it.
Tires are simply rally block tires.
I found a dozen “rain covers” available from Tamico and made one originally for the TA07 fit. The bottom half is bolted flush to the carbon chassis from underneath, they attach to one another with velcro.
I threw on a runner shell - Mon Tech Golf R  and went flat out over crest. The thing was super fun, super fast and great handling. The covers weren’t perfect, neither was the fact my belts and diffs are exposed but I was very content and inspired to continue.
I let the chassis thaw and I wiped it all dry 😄 .
Tamiya 51289 - Subaru Impreza WRC 2007
Bodyset of choice wasn’t revolutionary but I always wanted one done well. I found a good position the body sat and took the time to cut out the front air vents and paint it.
I decided the rear lamp decals didn’t cut it visually so I hand painted clear red on the tail lamps. I added mesh to the front air vent for a bit of up close detail.
I chose to finally add lamps to a bodyshell, it was my first time so I have no idea what I’m doing. This “killerbody” LED controller unit is a bargain and responds to your esc/steering input.
I carefully hot glued the LED in place from the rear and mounted the light buckets. It’s completely transformative aesthetically compared to lamp decals.
There’s times when things need to be really pretty and times when things need to function. The underbody is just that pure function. I’m liberally hot gluing after double siding taping down things to ensure they are completely solidly mounted.
I found a interesting and convincing anti lag exhaust which reacts to vibrations. It’s incredibly realistic looking. It’s completely randomized in speed and duration. I just love that someone took the time to figure it out. It has two LED’s ( blue and orange ) and circuit wizardry inside. It’s self powered by a series of button size / shaped batteries.
I made a bracket from a coat hanger, I hard mounted it to the body with hot glue and with extra supports.
I decided I wanted to have the reflective side windows some year wrc cars had so I made some templates and cut them out of reflective vinyl.
The black wheels for asphalt although being very good grip they do nothing for scale I tried to find the most matching wheels available paint colour.
Side by side the comparison between original plastic cast “gold” wheels to the Tamiya painted champagne is a enormous improvement.
 Visually things are hitting their peak point. I’m very happy where this shell has taken me. There’s still plenty of work and documentation to be done however!
Since I truly will drive at full tilt with this thing I won’t go any more detail really, although I know it can look even better by continuing to add exterior parts for detailing. Maybe the next body.
  • Like 14
Light test is successful. I turned off the turn signal function but the live brake remains. When the vehicle is idle after a few moments the amber hazard lights blink. Very cool.
I mounted the LED unit controller and futaba receiver directly to the body. I have a cable labeled E for esc and S for servo that need plugging in when the body goes on. Seemed like the cleanest way to have it setup for now.
I tried a few quick version of inner fenders / splash guards and decided on using primarly the food containers. They are the perfect diameter and even have a mounting lip if you cut them evenly horizontally.
I will elaborate on them further with paint, inner bike tube and lexan where I see fit.
For areas near turnbuckles it could work perfect with rubber as they can move freely while working through a rather tight hole in the material. Maybe.
These should be a fun addition and first time experiment for me. Nothing wrong with some overkill live telemetry data and HD footage of outings.
Skyrc GPS, old but still good Gopro Hero Sessions
I also rebuilt the rear dampers and added fresh oil.
@naturbo2000 Thank you! What´s the use of doing anything without sharing the ups and downs with likeminded others.  This forum has been an amazing inspiration for decades for me, it´s a long time coming for me to take the time and contribute.
Thank you again for the kind words! Make a thread! :)
Made some more unnecessary / necessary? visual progress :)
Mudflaps - Tape placeholders the visual ones will be just that - visually appealing - the non visible functioning inner flaps and lining will be not that pretty.
Front Lip - Rubber - I am very happy with, I didn´t think about the idea until i studied these two reference pictures a bit. Really makes the front pop with material diversity.
