DrGoatboy 132 Posted November 16, 2022 I really fancy a tt-02d as I have never had a go at drifting before, but I really want a MK2 escort shell to go on it. But I can only seem to find mf-01x shells. The wheelbase looks about 1cm out so I don't think it will fit. Can anyone either confirm if the mf-01 shell will fit a tt-02 or point me in the direction of an escort tt-02 shell? Share this post Link to post Share on other sites
DrGoatboy 132 Posted November 16, 2022 2 minutes after I post I find one!! https://landlmodels.co.uk/products/tc022-ford-escort-mk2-v2 Any other options gratefully received. Share this post Link to post Share on other sites
Busdriver 6209 Posted November 16, 2022 Try Kamtec. They have mk1 and mk2 escort. Detail is not as good as Tamiya but with the right paint and stickers they look ok 1 Share this post Link to post Share on other sites
DrGoatboy 132 Posted November 16, 2022 19 minutes ago, Busdriver said: Try Kamtec. They have mk1 and mk2 escort. Detail is not as good as Tamiya but with the right paint and stickers they look ok Legend! Thank you.i knew there was a company to use but I couldn't for the life of me remember what it was called This looks perfect https://www.kamtec.co.uk/p/ford-escort-mark-2-decal-set-1-10-rally-body-shell-abs Share this post Link to post Share on other sites
Busdriver 6209 Posted November 16, 2022 1 hour ago, DrGoatboy said: Legend! Thank you.i knew there was a company to use but I couldn't for the life of me remember what it was called This looks perfect https://www.kamtec.co.uk/p/ford-escort-mark-2-decal-set-1-10-rally-body-shell-abs Just remember that one is ABS not Lexan. So you have to either cut the windows out, paint them on or use stickers. They are a bit heavier than Lexan. Also you need to use normal paint not PS ones. They do do a Lexan version if you prefer. 1 Share this post Link to post Share on other sites
DrGoatboy 132 Posted November 16, 2022 40 minutes ago, Busdriver said: Just remember that one is ABS not Lexan. So you have to either cut the windows out, paint them on or use stickers. They are a bit heavier than Lexan. Also you need to use normal paint not PS ones. They do do a Lexan version if you prefer. Thanks again. I had spotted that. Can't decide which one to go for. I must admit I hate painting lexan!! (But it probably makes more sense in every other way) Share this post Link to post Share on other sites
Busdriver 6209 Posted November 16, 2022 Unless you want todo construction work on the body the lexan is best. Share this post Link to post Share on other sites
