A friend of mine had a Pajero back in the 80s and I always liked it. The rest of us had buggies, I think this was the first hard body I’d ever seen. He moved away and I kinda forgot about the Pajero.
A while back I saw one again and all the old memories came back. Took a while to find one, but I bought this in the summer.
I just got round to looking at it. The body is a bit beaten up, lots of random drilled holes and roll-over damage. The chassis is good though, and the gearbox should be ok once all the solidified grease is cleaned out.
I don’t know that much about this chassis, I’ll put some new radio gear in it and give it some light running. It’ll basically be a shelfer though.
Nice.  I too had that Pajero back in the day.
Today my 5844 I bought new a few yrs ago  looks like this.  GL with your restoration!! B)
More pictures in my profile page.
First question … does anyone know what motor pinion it uses? I only have a 15 tooth and that doesn’t fit. The manual doesn’t say, and I found articles online saying 18 and 20 tooth … not sure which is correct though.
@AshRC nice!
The Pajero is one of my favourite Tamiya cars, at least visually. I picked up a beaten-up re-re a few weeks ago.
I’ve already grabbed a new body and will probably order repro decals as it’s one of the few kits I really love as box art. I’m also hoping to fit the more scale rims and tyres.
Broken bodywork cut out and replaced, b-pillars added and many holes filled. I didn't try to repair all the damage.
After primer.
Next step is decals and interior. @Willy iine - I see you've put clear windows in yours. Tamiya have long since discontinued the glass for this and the Montero, so I'm thinking of getting some 1mm smoked acrylic and making the windows myself. I was wondering if you had any hints / tips from when you did the same?
It's actually quite easy to make as the window plane is basically flat.  I do plan to redo the front windshield down the road where I would allow the glass into the frame recess by adding a perimeter frame.. this will allow the glass to sit flush with the window trim.  I just did not have enough polycarbonate material at the time.  :ph34r:
I’m going to have to do that, I used thicker plasticard on the repair to the windscreen surround, so the back won’t be flat any more.
I’ll let you know how I get on …
  • 4 weeks later...
Finished.
I made the individual windows from 1mm perspex, and added window tint film on everything except the windscreen. I'm not particularly happy with the tint as it's already started to come away around the edges in a few places <_<
I put in a Tamiya 4x4 driver but he looked too small, so in goes Willy. He fits perfectly onto one of the MSC mounts, just needed a little booster cushion B)
Looks great.  I made some clear glass for one of mine many years ago (camel pajero in my showroom ) . I also made a basic cockpit and fitted a modded Scorcher driver .
I'd like to see that if you have any pictures you can share.  :D
When I saw this post I remembered that I had a body. After moving house I found him in a box in the attic with other things... It was a few days of searching
Thanks AshRC😊
