Have a good amount of TXT-2 dampers in use on various trucks and a lot are starting to leak due to the red upper oil seals getting hard & brittle.  Part number is 19805486 and I've seen them here and there, but looks like they're out of production.  I need about 20 of these and would rather just buy in bulk and be done with it.
Question is - Is there an alternative that is readily available and work in these shocks?  I know a lot of you guys are pretty familiar with Tamiya CVAs and maybe there's something else that will work.  I can get the bottom o-rings in 10 packs cheap just about anywhere, but the top seals are not so easy to get.
Yea, that's it.  I saw that TTP has them but they only have a few.   Looks like they're used in a ton of models, shme they;re not more readily available.
I had a look through various shock seals on Tamiya base database and your part number 19805486 fits the 58181 Stadium Thunder truck and so does part 50600. It is a bag of 6 seals in a kinda green colour. Looks like it might fit according to the vehicles on their lists.
Hopefully some can verify that.
RCMart have them at $2.50
Thank you, the exact sort of info I was looking for!  They do look the same, hopefully sizing is correct.  I'll order some and check them out.  They say for Mini CVA Dampers which I guess is what the TXT-2 uses, just 8 of them.   Thanks again.
