Now I believe this may be a first? A build thread for a TRX4. Hopefully this will not create a rift in the space time continuum but here goes. Firstly I should explain the title. The chassis that I am building is the TRX4 Premium Builders kit. So it comes with full bells and whistles, portals, locking diffs, 2 speed transmission, cruise control etc, etc. The one thing it doesn’t come with is a body. I’ve always liked the Sport version with the exposition rack etc so that’s what I’m using. Hope that all makes sense. So difficult to photograph but this is the contents of the box along with the bodyshell. 6D8FFDFE-7A1A-482A-B396-E64DF7831E02.jpg All the bags are labelled and correspond to a complete section of the manual. Unlike a lot of Tamiya kits this comes with full sealed rubber bearings, oil filled shocks( well empty actually but you get the idea). For example stage one is the transmission so you select the transmission bag 3D5D5E6A-C864-4FB5-AC96-302ED08AA9FF.jpg and in that you find this little lot 82234CCB-8F51-43B6-A226-7535B7A6DC1F.jpg and this 0F3BDDA6-B5F2-4C76-B711-70ADB73C96FF.jpg tells you very clearly what to do with it all. I say that with some emphasis because when you get to the end of the section and you have a big bearing staring at you you haven’t read it carefully!!!! As far as I can tell there are no spares anywhere. Result unbolt all you hard work and see wher the bearing should have been hiding!!. Will post some more later but I have to say so far it goes together like a dream.
43 minutes ago, BuggyDad said:
Tamiya - you could sue them for stealing your box wrench!
Actually it’s not an exact copy. It is longer and polished!!!
@Busdriver I'm pleased to see a build of this. I planned doing a build thread when I started building my TRX4Sport in 11/2020... but as it usually goes with me I get carried away with building and forget to take pictures...
20201123_220829.jpg Mine is the actual Sport kit, so no electronics included, no two speed transmission or diffs...
This makes the transmission (it seems to share the same case?) a lot simpler than on yours.
If you don't mind I'll put pictures up (if I have them and can find them as I'm temporary on an old cell phone untill my regular one is repaired) of the steps where the sport differs from your kit.
Off topic: I see you have the same problem on your Revell glue bottle as I had, mine cracked so bad I had to get another bottle for it.
I believe this will only happen if you fit a Conrad motor.
exposition rack
Is this a rack that stops for a while to explain what's going on, in case you missed it during all the dialog and action bits? ;)
In all seriousness, I love the Sport body - and when you consider how much extra you normally have to pay for all those add-on scaley bits, it makes the Sport kit good value for money.  Since you're fitting yours on a full-fat Premium kit, you'll have the ultimate sleeper wagon out on the trails.
2 minutes ago, BuggyDad said:
colour instructions
I found this very refreshing. Equal quality wise with Tamiya and Kyosho but with an extra show element kinda; I like!
Glad to see the pictures. The glues been cracked for ages. Still doesn’t seem to leak or dry out so as they if it ain’t broke don’t fix it!!!
That’s the theory!!!! As for a Conrad that’s just too close to the dark side Traxxas is one thing…….
Just realised one other difference with the sport kit and that’s the wheels. I’m probably going to fit some Injora beadlocks with Hyraxes to mine as opposed to the stock ones.
I bought Injora beadlocks. I haven't run them yet but the one I assembled went together perfectly. Also, just got an email from them - small discount on currently.
Yes I got one of those as well, just don’t need anything at the moment ☹️
1 hour ago, OldSchoolRC1 said:
Traxxas doesn't do many kits, but when they do, they sure do it right. Enjoy the build!
Thanks, I have to agree.  I think the nearest Tamiya I’ve built to this is an XV01 and by that I mean the way it goes together. Everything just fits, the plastic is excellent and the hardware is all good quality machine screws. Where there is metal to metal there is pre applied threadlok. . I think my only issue with the builders kit will be the fenders as I think they will be a tad wide for the sport body. Nothing that Dr Dremel can’t fix. I could have bought the narrower fender set but hey where’s the fun in that!!!
Interesting they supply bumpers on a chassis without a body. I believe Element doesn't. Your kit I think has more included in multiple areas. I've bought Injora ones but they're a shot in the dark - don't know whether they'll suit.
Language difference here. The do supply bumpers but what I’m actually talking about is inner fenders/wheel wells. They are designed to fit the Old Bronco/Blazer shells I believe so are wider. They do a replacement set called a narrow fender set which fit under the narrower Sport body.
Oh right, sorry misunderstanding. Still, Element doesn't provide them either!
I'd have thought they'd be very body-specific?
Maybe Traxxas have more of an expectation you'll fit their bodies, where others might be more inclined not to have any expectation as to what you'll do with the chassis.
Following on from here I have done both axles , the chassis and installed the electrics. There’s nothing really to say other than it just goes together well. I fitted all the electrics switched the power on and everything worked just as it’s supposed!! So here are some pictures.
A429A4D6-F235-4181-AABC-021D8D123398.jpg AA880572-8F39-408D-BD35-5E5ADC820C6C.jpg 8ABB75FF-B159-410E-8E7B-D215884850EA.jpg C1DF9C63-7903-46B8-9B62-8162F2832BCB.jpg 87BCED1E-07BC-48A2-BC73-00ECE08B5CC3.jpg FD642F59-1727-4333-84FF-C073C4E3B8B2.jpg 9CBFBD01-0686-4F02-9FF1-2DBA820CB2A9.jpg 3D39614F-5D2E-47CE-8598-11D6F1A8922E.jpg D53886D1-7805-4F42-9433-555E00FEAF90.jpg  4FA3D7D3-38BA-49C2-89A5-230785F57BB5.jpg  CE767232-2E95-49DB-B742-EA76C3CAC2B2.jpg 88F8C769-B191-4745-9797-CF6ACE4A7440.jpg 95CA62F2-FAC8-447B-81F0-D773AD4B6A61.jpg F93602D0-CC5E-4D8C-B22E-93D7F533E12D.jpg 45E0B52A-6980-47C6-B09A-B76E320666C8.jpg E4761B34-46B0-4224-B5EC-8939CF7EB2E4.jpg D1B0F1ED-6443-4EBA-9DEB-76D292DDE106.jpg ED2B0455-4703-4211-9F09-6B23683856CF.jpg D1F410B4-29B1-4B60-85BE-D988477BDA48.jpg F7DCA686-3CD2-44F8-9749-187D0A688730.jpg 622BFA78-F6B1-4D88-9591-59EB9AE834EE.jpg 43B3F104-5CEB-4136-B6E8-5E6809F9362A.jpg………. Phew that was a building session!!! Electrics look a bit of a rats nest but will look fine once the receiver box is closed. A tip to anybody who plans to do this build mark each plug with an identifier of some form as they are quite difficult to trace back to source. I didn’t!!!…….
Apart from the drive shafts ( no I didn’t forget) that’s the construction basically done. I have to say this is not a difficult build but none the less is quite satisfying. The only thing of a similar style that I’ve built before is the GMade GOM and I have to say this thing is in a different league, and I accept a different price point. It just all fits together so well. The ground clearance with the stock wheels and tyres and the portal axles is just amazing. It’s like it’s got 2.2 wheels and tyres not the 1.9’s that it’s actually got. I have a little bit of playing around getting the body sitting right then it’ll be on to decor!!!
I looked the kit up and made *gulp* noise when I saw the price but there is a lot of bang for your buck. Glad you're enjoying it, I reckon it will be a great performer out in the wilds.
