matisse
BB01 BBX RC : speculation/rumours/hope
13 minutes ago, Ministrone said:
Its a lovely looking thing, I bet it won't be cheap.
Yeah, it could well be out of my price range.
2 minutes ago, Twinfan said:
Interesting that the box art has a brushless motor - is that a first for Tamiya?
Ignore my post
I have put it on my "wishlist" and will get one, but I think it's looks a bit dull and cheap. It's kind of like a mix of Scorpion, HPI 5B, Wild One, Falcon and Losi SCB. Nothing really new, but that can possibly not be exptected anymore? Apparently driver figure recirculated from The Fox. Nasty chrome on the wheels, which will come off immediately when I get the model. Also, with rear trailing arms, I wish Tamiya had gone for double front trailing arms too, but double wishbones up front in combination with rear trailing arms is authentic too, albeit places the model in the `90's and not '70's/80's like the SRB. With a wheelbase of 283mm, Tamiya really needs to make a new VW Bug (baja bug) body for the chassis.
It does look decent, I could well be tempted, more than I was by the TD models anyway. Really good to see bearings😯 and UJ's are included too👍
What's up with he name though? Where is the name?😂 Tamiya always has a cool name yeah? Now it's just three letters... BBX🤨
The more I look at this the more I like it...
The multi panel body work is cool, I could see this one being sort of hot rodded😎
Ordered! Couldn't resist. Very excited to get a new model, can't wait to build it.
2 hours ago, Elbowloh said:
Really? Thought it would be like £400!
Email from Jadlam says 5p under £360
I should add, I bought from the Tamico link shared on this thread, and quickly because the €252 price was too good to miss. Especially as I've just had an email from Jadlam at £360! 😱
56 minutes ago, Tamiyastef said:
I wanna see that video !
Cut before the action shots though!
I can’t stop looking at it! In my opinion it totally puts the kyosho dirt master aesthetic in the shade.
7 minutes ago, ruebiracer said:
Seems you are on the toyfair @qatmix!:) Very quick post!
Could you pleas give us some news on the new M-Chassis derivate and the Fiat Abarth? Not seen pics so far!:lol:
Have fun,
Matthias
It’s not actually here yet, it should be in display later.
Some info on the Hop-Ups here:  https://kentech.wordpress.com/2023/02/01/tamiya-nuremberg-releases-full-information/.  What's the difference between the kit supplied universal joints and the Hop-Up Dogbone shafts???
22068 BB-01 Dogbone Shafts (2 Pcs.)
This Hop-Up Option set is for use with the new BB-01 chassis. Use these precise and rigid drive shafts in universal shafts.
Item Contents/Information
• 63mm swing shafts x2
• Crafted in carbon tool steel.
• Compatible with the BB-01 chassis.
22069 BB-01 Aluminum Front Uprights
This Hop-Up Option set is for use with the new BB-01 chassis. Use these precise and rigid aluminum front uprights to upgrade the suspension.
• Silver-anodized aluminum front uprights x2
• Right and left side components feature the same shape.
22070 BB-01 Aluminum Servo Stays
This Hop-Up Option set is for use with the new BB-01 chassis. Use these precise and rigid aluminum servo stays to improve rigidity.
• Silver-anodized aluminum servo stays x2
22071 BB-01 Aluminum Slipper Clutch Set
This Hop-Up Option set is for use with the new BB-01 chassis cars to protect the drivetrain from sudden surges.
• Gear-integrated shaft (20T) x1
• Slipper screw x1
• Plate A x1
• Plate B x1
• Slipper pads x2
• 1050 ball bearing x1
• Spring seats x2
• Spring x1
• 2.6mm lock nut x1
• Adjusting spring tension allows change of slip timing and acceleration traction, to give more stable performance.
• Features precise and durable gear-integrated shaft.
