whahooo 465 Posted December 26, 2022 I´ve asked that in the past, but... ...are there any oilshocks for the Hornet Grasshopper? I hope with the 1/24 boom, there will be some Oilshocks that would fit the Grasshopper directly. There is video of a guy that uses CVA´s and the Grasshopper performs really well: https://www.youtube.com/watch?v=cvhSps_W4AA Share this post Link to post Share on other sites
alvinlwh 5846 Posted December 26, 2022 I am building a GH2 right now and this is what the instructions show. Basically just 70mm and 87mm Share this post Link to post Share on other sites
Super ally 410 Posted December 26, 2022 Just keep them as they are as it takes away the character of these buggies Share this post Link to post Share on other sites
whahooo 465 Posted December 26, 2022 I don't think that internal spring shocks in the front would destroy the character of the buggy. I hust don't know how much mm i would need in the front and in the Back. There are 60 mm shocks available as internal spring shocks Share this post Link to post Share on other sites
Fuijo 867 Posted December 26, 2022 As far as I can tell when watching the slow-mo from that vid, the rear shocks aren't really moving at all. The distance between the top of the tyres and the wing seems to remain constant to me. I think that the reasonably flat surface and the hornet-style tyres are making it seem to work when it actually isn't. That's how it looks to me anyway. The front is certainly moving quite a bit tho'. Share this post Link to post Share on other sites
Andreas W 1429 Posted December 26, 2022 If you change to GH2 wishbones you can use 50519 like in the instuctions Alwin posted. 50520 for the rear. I run 100cst oil and 3 hole pistons all round. The biggest difference/improvement came when I mounted Kyosho Scorpion wheels rear. The most hassle free solution will be Frog hex, Javelin wheels in preferred color and Scorpion tires. Share this post Link to post Share on other sites
El Gecko 1329 Posted December 28, 2022 On 12/26/2022 at 1:28 PM, Fuijo said: As far as I can tell when watching the slow-mo from that vid, the rear shocks aren't really moving at all. The distance between the top of the tyres and the wing seems to remain constant to me. I think that the reasonably flat surface and the hornet-style tyres are making it seem to work when it actually isn't. That's how it looks to me anyway. The front is certainly moving quite a bit tho'. That was my thought watching it too, it doesn't seem all that much different than a normal factory setup, and it's not being pushed very hard on that easy surface. Converting a Grasshopper to the Hornet style rear end makes a bigger difference than front oilshocks in my experience. I doubt any 1/24 shocks would be strong enough to support the front of the car. Maybe some touring car shocks would work with the GH2 arms as suggested above. Share this post Link to post Share on other sites
