Hi all,
I found this used RC toy and wanted to Tamiya it!   A few options are being considered.:
1. Comical chassis GF-01 (4WD)
2. Comical chassis WR-02 (2WD)
3. Wild Willy chase with Lunchbox tires.
4. TA-02 with 3D printed chassis
#1 and #2 are comical and wheelbase matches. #3 wheelbase works and is monsterized. Problem is with high center of gravity it will tip often and I am not sure I want to frequently to flip it back onto its wheels
Target now is #4.  A quick drift car with minimal flipping over. This will also give me a chance to learn to design and 3D print for the first time.
Fingers crossed 🤞
Wheelbase 175mm
Track width 200mm
Length 320mm
Width 230mm
  • Like 10
  • Haha 7
Maybe you can hack the Grasshopper rear gearbox in or is that too high? Even better but pure blasphemy: get an old Golf chassis (58025) and hack that into the right dimensions? :rolleyes:
I would be exiled from Tamiya Club for touching 58025 chassis for SBSP conversion 😵
Just noticed Tamiya tire is 63mm in diameter. Stock SBSP is 73mm rear and 64mm front. If I was sticking to RWD, I could make the rear wheels larger in diameter for a dragster look…
Awesome. One other option you have is an MF01x. With no spacers the wheelbase would be 171 mm, which is probably close enough? Could you go for Tamiya racing truck tires (70 mm O/D) as another option.
This thing will be great regardless. Can you and @GeeWings please have a race with his Mario-Kart?
I did consider the M class but wanted to match the existing track width at 200mm.  Full size touring was as close to stock SBSP.  M chassis would be too narrow.
Mario Kart is awesome!   I still play video game with my kids
 you can add longer TL01 arms to greatly increase the track width. Or even GF01CB arms. However I'm sure this will be fantastic! I am not familiar with this chassis but it looks nice.
46 minutes ago, Frankster said:
Panicked and thought the batt would not fit hard chassis.  Good to go!
It was meant to be!
I was looking at Comical but batt is too high and will prob tip over.
M chassis with TL01 arms is a new approach.  Never heard of this hack before.  Maybe next time as I am already down the rabbit hole with the TA02 chassis
Comical chassis use same geometry arms as TL-01, but slightly longer, so you can use them on M-chassis, too. Or even TL-01B arms, but that might be too wide.
Picked up min requirements:
-bearings
-drift dish wheels to make the car look stock
-drift tires
-alum motor mount (weak point)
I will upgrade motor at a later point, let’s get this started first
Rear ball diff completed
Rear stock suspension assembly completed
It is a brand new kit but an old design.  I am surprised the amount of play in the suspension joints
Posted (edited)
Front gearbox and suspension completed.  Notice the center drive shafts are not aligned in both x and y axis
Edited by Frankster
Spelling
I was not sure if the wheels would hit the battery.  Installed new dish wheels (to be painted later) and drift tires.  The wheels clear when at full lock.
Next I need to review existing body structure.  TA02 bumper will need to go or get cut down in size
On 1/19/2023 at 3:06 PM, Frankster said:
Hi all,
Fingers crossed 🤞
Wheelbase 175mm
Track width 200mm
Length 320mm
Width 230mm
How about some fries with that
Printed chassis arrived.  Overall sturdy for what I need.  This new 2nd printed chassis fixed  mounting hole issues from my first attempt.
ADE53B03-921B-440A-A180-8163E41F30C3.jpeg.d94ed419c56d87427e48d9401cb0046f.jpeg9DC4C40C-7D47-4708-829A-4B26B08D3DCB.jpeg.5ebfa3ea20df08097b591d17df879a3e.jpeg
This one also has 2 problems.
I did not chamfer the rear part and the chassis does not fit with the rear gearbox   I will try filing this down to make it fit.
second I did not measure the front gearbox holes properly.
Overall I will file the rear part of the chassis and drill larger holes in the front to confirm if there are any other issues.  Afterwards I will reprint the bottom chassis again
Installed and modified the chassis to for north gear boxes   Not problems popping up from my print.
Cut / remove additional surplus attachment point to fit battery
Gap in attachment points
Need to more space between top deck and bottom deck for battery and servo
shift servo back
need a shorter turnbuckle 33DA684F-B813-4809-A0F2-FD6CDBEA5F36.jpeg.c2303689a4fa795abae2bf1090304601.jpeg
Overall working well   Still need to reprint top and bottom chassis pieces
