Well heres my situation
I recently got a kit of Amazon that came with the TBLE02-S esc. I have hade this before when it came with the Holiday Buggy. Back then no problem at all. Just installed it and switched it on and everything was fine.
But now I cant get it to work no matter what I do. Spent three evenings now and about to give up. Just cant figure it out.
First when installed, the channel 1 servo worked fine. Now nothing works.
Is threre a chance that the servo can be damaged when I fiddle around switching from brushless to brushed? connecting and unconnecting cables etc?
Ive tried to rebind radio and reciever (Futaba 3PV and R203GF) reciever now has steady green light.
So far I have done this:
Switched to brushed mode (Have a standard silver can connected) green light solid now
Done the high end setup as described in manual.
Tried another esc Carson 70 with same result
Changed to new batteries in radio
Make sure the  nimh batteries are charged.
Im worried that , with all the ways I fiddled around, the esc in some way has shortcircuited/damaged the reciever or servo. Could this be possible in some way?
One problem (at least to me ) nowadays is that theres almost no hobbyshops around where you could get hands on help. At least not where I live.
I watched all youtube instructions and read all I could find online
Anyone experienced something similar?
Any help highly appreciated
Thank you for your replies
It turns to solid green it has never made any sounds
What baffles me is that the servo worked initially
3PV…I use the same radio.  Though that complicates the troubleshooting process, it is still highly reliable paired to the TBLE02.
First confirm that the radio is set to S-FHSS for the R203Gf and not T-FHSS for the telemetry models.
The ESC isn't firing up correctly by the sound of it, so as SupraChrgd82 says I'd check your transmitter and receiver are connected correctly.
The ESC should flash and beep when fired up to confirm settings. A solid green light is not standard, so I'm wondering if it's faulty.
Just checked. It is set to S-FHSS
Is it possible that this has broken the reciever since nothing works now?
First of all thank all for your kind help
While trying again this morning I did the following. I changed from  S-FHSS  to T-FHSS and saved that setting. Then changed back to S-FHSS and now steering works again. So guess that the reciever and servo is fine.No throttle what so ever though. And no beeps
I have another brushed only ESC (Carson 70 Dragster also never used) that worked right away. I wanted the TBLE becaue its brushless ready
Could it be a setting in the radio thats not correct?
Presumably you are trying to test it with a motor attached (apologies if it's a daft question!). The default mode bizarrely seems to be for brushless mode (when they are supplied in a kit with a brushed motor).
The ESC should give some indication of lights when it's happy or not (such as wrong motor type indication), in a similar way when it's working to showing when it's hit max throttle for instance through the LED (IIRC it's off when on (somewhat unintuitive), green under throttle, and then goes out when hits max throttle or reverse for brushed mode).
I often struggle to set them up as I can't easily tell the difference between the orange and red LED colour, but once done they tend to just work. Like someone said earlier, LED just being on doesn't look right.  It should just beep once and then go out when it's turned on.
A solid green LED with no sound on the ESC is not normal operation according to the manual.  It should beep and flash initially to indicate the current settings, then go off.  If accelerating not at full throttle the green light should be on along with a constant noise.
It sounds like the ESC is faulty to me, especially if everything works OK with the Carson ESC.
6 hours ago, Jorgen said:
Ok thanks. I wonder how Amazon will handle this since the kit is finished:wacko:
Well aside from the fact that to you couldn't really (honestly) return it as the kit has been built, those ESCs regularly sell for sub £20 so as @Twinfan said just accept it and move on, especially if you have something better for brushed motors to run with.
I'd offer to test it on my Futaba for instance, but it would cost over £3 (assuming UK) each way to post it...
Thanks a lot for your kind offer. I found a new at a good price on Ebay though.
Never had anything not work from Tamiya
Well if that is the same, you'll know it's user error or not. 😉
