futureworks
Who made this FF01 rear sway bar set?
Clearly a vintage item, and I know Rainbow Products produced a front sway bar set for the FF01, but I wondered of anyone recognises this rear set and who made it? The front one made by Rainbow used white ball connector parts (shown at the top of pic 2),  so I suspect this rear one is by another company, like Tech Racing or one of the other Japanese aftermarket parts producers from back in the day. Any insights fellow TCers?
Don't know who did the original, but you could make something similar out of some piano wire and current tamiya parts.
53827 stabilizer stoppers
53644 stabilizer end
54869 open adjuster long
54248 23mm turnbuckles
50592 ball connectors
If you drill 1.5mm holes through two of the adjusters just behind the open ends and mount those to the shock tower like the one in the pic you have. Make the bar by bending some 1.5mm piano wire in the right shape and use the stoppers to hold it in place. Stabilizer ends on the end, ball connectors in the arms, and use the other adjusters and turnbuckles to make the droppers.
Thanks @ThunderDragonCy, good shout! I’d still be really keen to find out who made the pictured rear sway bar set as you never know, these things have been known to turn up!
Anyone?
