You will still need some braking... not a lot on a HOR but some. The brake/reverse logic is managed by the ESC, not the Tx. So changing or adjusting your Tx will not change anything. The 1625 is Forward/Brake/Reverse. It should not be a problem. Just don't cycle the trigger/stick to full brake-back to neutral-brake again. Full brake on a HOR will more than likely cause you to crash instantly anyway so it should not be a problem at all.
My TT-02 came with a Carson 70a ESC with 3 modes on it, Car, Crawler and Boat -
"Jumper settings:
Model selection:
„F / B / R“ forward- brake-backward
„Boat“ forwards -backwards (without brake)
„Crawler mode“ forward-backward (handbrake)"
I think that Crawler mode just gives you forward and brake. I'll try it out tomorrow when I'm at the track.
I just went and tried it there, it's ****** all different to the normal forward-brake-reverse on all modes :/ Unless you have to reset the ESC between changes and I was doing something wrong.
On 2/9/2023 at 10:12 PM, alvinlwh said:
Unfortunately don't work. It powers the motor at neutral, only stops on nearly full reverse. Even with trim and subtrim set to R120%.
Sorry that did not work for you.
