Hi all;
looking for a brushelss motor and esc to up my speed on the stock tamiya neo scorcher (silver can).
I only want to replace motor and esc (keep my nimh battery for now)
my criteria is simple:
  • more speed (prefferably a lot more but the car should still hold),
  • longer run times (so less batter drain),
  • easy on the pocket (i want something up to 60usd range if thats possible),
  • brand motor? (i am not sure i need a branded one),
  • sonsored? (prefferably)
i think thats it :) i am not sure if there exists a motor that fits my needs,
BTW, I am a hobbyist not a racer... if I have a 150$ car so I dont think putting more that 50-60USd on this combo makes sense...
thanks for your help!
I think the challenge will be finding a motor that gives you both more speed and longer run times.  You usually get one but not both.  And 60USD is not a lot for a motor, ESC and sensor cable!
amazon has many combos of non branded stuff or less known stocker brands
for example goolRC: https://www.amazon.com/GoolRC-Brushless-Upgrade-Waterproof-3300KV/dp/B095GNR1N2/ref=sr_1_23?crid=3CKC9S8DLGZS4&keywords=540+brushless+motor+esc+combo&qid=1675760640&sprefix=540+brushless+motor+esc+combo%2Caps%2C188&sr=8-23
i have no idea if its good or not i can probably look for reviews but there are plenty like these there...
I believe all these types are sensorless, sensored combos are usually more expensive.
The point I was making is that I think you're going to have to compromise.  I don't think you'll be able to get everything on your list so you'll need to decide which items are the most important  :)
if I bumped the price a little. i can see : https://www.hobbywingdirect.com/collections/combo-special/products/quicrun-10bl60-sensored-esc-combo?variant=25753352584
can it be ran with NimH?
is this the "best" deal for what it provides from a branded company?
maybe you have other suggestions?
thanks
I have that exact setup with a 13.5T in a Fire Dragon that I run on 5000mAh NiMH packs.  It's quick.  Very quick.  But runtime is a lot less than a silver can.  Like I said, you can't have it all!
interesting - can you share why you chose the 13.5T vs 10T - thanks
I already had 4.5T, 5.5T and 10.5T Speed Passion motors lying around and having tried the 5.5T it was too much for the Fire Dragon!  :D
I bought a 13.5T as that seems to be a recommended level for older re-re kits, and if it wasn't quick enough I could always swap in my 10.5T.  13.5T is very quick and about as much as the car can handle so I've stuck with it and it performs really well.  The 10.5T will be going in my TD2 when I build it - that will be a rocket as it's 2WD, but I'm hoping the more modern chassis will handle it OK.
Amazon specials you take your chances.
Hobbywing dominate hobby-level ESCs, good support and performance, really no need to choose any other brand unless you want something very specialised.
Sensorless systems are cheaper, tend to be waterproof but not as smooth at low speeds. Good for high speed blasts.
Sensored systems are more expensive, won't be waterproof but give fine low speed control. Better for technical use and racing.
All ESCs will work with NiMH but NiMHs can't sustain the power demands of fast motors.
hmmm
so maybe for my use case sensorless is valid? i am not racing, not intend to race, just want to enjoy my car :)
You can if you use Li-Po instead NiMH.
33 minutes ago, gkatz said:
hmmm
The combo you showed will work perfectly.
as I said, you can have everything just try to make the transition to lipo.
a 2s 5000mAh will run this goolRC combo for more then 45min I am pretty sure.
it is mostly up to gearing, with adequate gearing you can manage to have better longer runtime
1 minute ago, Fabia130vRS said:
i have a big problem with tamico as their lowest intl ship rate is crazy high @ 30eu...
the ebay combo, i guess its like the amazon ones? non branded combos. I do not know how to check if they are any good...
I had this Gool RC combo 9T in my lunchbox. With 3s and 19T pinion instead of the 11T pinion.
They are good, it does what a motor is supposed to. They are not really waterproof thats it. My esc caught water in rain conditions, water running down the battery cable and burned.
The thing about this budget combos is, the gool rc is a smaller rotor, basically a 380  rotor in a 540 can. Something like that. But honestly, it does the job without issues. Plug and drive, the cheapest is the best.
As for the battery, I don't know where you are from, but any hardcase 2S is in my opinion safer then the soft case (no case) lipo's
I guess for offroad driving the sensorless gool rc 9 T is fine.
https://www.ebay.com/itm/385342166072
Other wise...
The hobbywing 60A sensored brushless esc is a best buy. (2S-3S)
https://tamico.de/Hobbywing-QuicRun-10BL120-120A-Sensored-Regler
This I went for, the regular LRP SPIN (47€) not PRO. both 100A (2S-4S)
https://www.rc-kleinkram.de/products/02-80250?c=2488
This one is also a good sensor esc. (2S) TS50
https://www.rc-kleinkram.de/products/26-sk300060-01?c=2488
I trust people online, I do buy used motors, you can find great brands like, LRP, MuchMore, Losi and other sensor motors from 5.5T to 17.5T on ebay kleineinzeigen or ebay (a bit hard) You just need to know what you are looking for.
eventually i will move to lipo - I am trying to trasnition slowly and not jump ahead of myself - I need to pace it.
Honestly you're better off just running LiPo if you want to save money this time around.  It will give you noticeable increase in power vs  your NiMH.   BL motor/ESC combo can be tricky as modulation is a hit or miss .. and running hot motors will wear your car faster so there's that.  GL with whatever you decide!
May you please explain to me what do you mean with modulation?
If it is concerned about Battery > ESC > Motor matching.
There is an easy formula, I may not explain it well enough, but I use this…
So... Let say I am going to match a sensored Trackstar 13,5T motor...
The motor has a peak current rating of: 360A
So I am looking for an ESC that can deliver this power...
The hobbywing quicrun 10bl60 has a peak power rating of: 380A
that's a perfect fit...
Let's see if my battery will support this setup...
mAh * C rating = peak A current
you would need a race pack of 6600mAh * 60C = 396,000mA (396A)
or a 100C * 5000mAh = 500.000mA (500A)
For peak performance. Most people do not realize how important the C rating is for high-powered combos. Regarding Peak-Performance. You may not damage it if the battery is not strong enough. The ESC should never be the bottleneck itself.
In my opinion it makes sense, and it is something I fetched of quadcopter forums.
23 minutes ago, alvinlwh said:
This is a point many seem to miss.
Well, Hobbywing is not the only choice, SkyRC is a other often named budget choice.
https://a.aliexpress.com/_EIidxCd
In fact my very first brushless ESC is a TS50 and it has so much settings that your head will spin. It cannot do 3S or lower turn motors though should not be a problem for a first timer.
Good opinion.
My first brushless setup was a $90 Trackstar 80A turbo esc & Trackstar 13,5T sensored motor.
https://hobbyking.com/en_us/trackstar-roar-approved-13-5t-1-10th-stock-class-brushless-esc-and-motor-combo.html
This is picture of the setup of turbo and boost settings.
The gool RC on the other hand is a $35 ready to run set that will do hard work without a brain. It is idiot-proof and fast on 3s and high gearing. It is a matching combo. Just add a good battery.
@Fabia130vRS modulation is how much resolution there is in the throttle response.
Like the newer TBLE02S has poor modulation, 1060 has very refined modulation.  LeMans240s ESC had poor modulation, XR10 JustStock has super refined modulation when mated to LeMans240S BL , etc.
