So, the car is finally finished (kit form) and I went to start it, but noticed the flywheel barley sticks out of the bottom of the chassis.  If I were to use a starter box, it would get cut up on the chassis.  I already have a different flywheel on the engine (S&H engines on-road .21).  Should I use a larger flywheel 38mm for example or are there optional engine mounts to lower the engine on the chassis?
Any help is appreciated.
Thank you.
I use 38mm flywheel which does not protrude the chassis.
Look at your instructions if it makes any reference to lower engine mounts as an option.
Thank you for the reply.  I did go over the instructions, but didn't see any optional engine mounts as an option.  I will keep looking though.
Thanks!
