Thanks for allowing me to join!! I traded for a frog that has been modded to a Blackfoot.  Below is an inside pic of trans.  I know very little about these RC’s but it looks like there is a BF pinion on it and a stock frog spur.  If so is there any probably running it like that? I did order a MIP diff and a BF spur.   Thoughts??    Thanks!!!!
The 18/52 installed is the Torque gearing for the Frog.  It should be fine with the 10T BF pinion, as long as you are only using the Silver Can motor (or another mild motor).
