Busdriver 6209 Posted March 23, 2023 Title says it all. Buggies have but Touring cars etc don’t. Why’s that? What does it achieve?……………. Share this post Link to post Share on other sites
Twinfan 1252 Posted March 23, 2023 I think it's all about the jumps - no need for it on Touring Cars... Share this post Link to post Share on other sites
alvinlwh 5895 Posted March 23, 2023 28 minutes ago, Busdriver said: What does it achieve? Tamiya manuals are seriously bad in explaining what all those tuning 'holes' are for and what their effects are. I learnt more from the 64 page manual of my LRP than anywhere else (yes there is online but nothing beats reading a book), so here is what it says about kickup. 2 Share this post Link to post Share on other sites
Busdriver 6209 Posted March 23, 2023 Ok I get that but why does that work for a buggy and not a touring car? Share this post Link to post Share on other sites
Gebbly 588 Posted March 23, 2023 35 minutes ago, alvinlwh said: tuning 'holes' Really? I hadnt noticed. Guess that is tonights bed time reading. "Tuning Holes 101" Share this post Link to post Share on other sites
alvinlwh 5895 Posted March 23, 2023 1 hour ago, Busdriver said: Ok I get that but why does that work for a buggy and not a touring car? My guess is as @Twinfan mentioned, due to the jumps/off road element of a buggy? Allow it to take slope or uneven ground better? 32 minutes ago, Gebbly said: Really? I hadnt noticed. Guess that is tonights bed time reading. "Tuning Holes 101" Kamasutra for RC! 1 Share this post Link to post Share on other sites
BuggyGuy 1106 Posted March 23, 2023 For 2WD buggies they handle bumps a lot better with kickup - it's also a form of caster adjustment. You note that touring cars don't have a lot, it's worth pointing out that neither do 4WD buggies which would probably average about 6 degrees of kickup Edit: Also improves on power steering for 2WD 3 Share this post Link to post Share on other sites
Kowalski86 3034 Posted March 23, 2023 I always thought that "kickup" was about helping an RC ride over grass and bumps, for 2wd it helps "kickup" the front throwing traction back to the driven wheels. Touring cars don't need it since they're intended for on-road use, rally cars can benefit from it though. 1 Share this post Link to post Share on other sites
matisse 1581 Posted March 23, 2023 Afaik kick up and caster angle are intrinsically linked, more kick up = more caster = less snappy turn in. if you think about flat pan cars, many of them are 4wd and you can have similar effects on the steering using the front diff/spool. Caster/kick up adjustment re helps on 2wd off road. https://site.petitrc.com/reglages/BuggySetupGuide.pdf 2 Share this post Link to post Share on other sites
Pablo68 1049 Posted March 23, 2023 It is at least a bit to do with landing from a jump, it helps maintain steering control on landing (think of the buggy as it touches down from a jump, angled up enough for the kickup to be level-ish). Not needed for onroad cars as they aren't doing jumps (usually, unless you are being naughty). 2 Share this post Link to post Share on other sites
ThunderDragonCy 7878 Posted March 23, 2023 Kickup makes the vehicle transfer weight under braking more easily. You want this on a 2WD buggy to get the front to grip up on turn in. It does also ride bumps better. If you think about a car hitting a bump at speed, the bump is kind of a small ramp with an angle to it's face. If you match the front wheel path more closely to that bump angle, it will move out of the way more easily. You don't have as much on 4WD drive cars mainly because a lot of kickup would cause trouble in the 4WD system as the front wheels would try to wind up the prop shaft. 4WD buggies have as much as they can get away with. On touring cars, riding the bumps and weight transfer are less of an issue. That said, one of my favourite touring cars is the FF01, which has 3 degrees of front kick up. This must encourage weight transfer under braking to keep load pinned on those driven front wheels. 5 Share this post Link to post Share on other sites
Guest Posted March 23, 2023 Sorry, may have missed something. What is Kickup? That's new to me. Share this post Link to post Share on other sites
alvinlwh 5895 Posted March 23, 2023 1 hour ago, Hairyjon313 said: Sorry, may have missed something. What is Kickup? That's new to me. Will this help? 3 Share this post Link to post Share on other sites
qatmix 794 Posted March 23, 2023 For onroad you can actually have some 'Kick up'. It is usually referred to as pro-dive.. It will only be a very small amount that it is raised by (Usually adding shims under the front suspension block). More Front pro-dive = More initial steering, less steering around the rest of the corner. Less Front pro-dive = Less initial steering, more steering around the rest of the corner. lots of info for onroad here https://www.thercracer.com/2017/01/tamiya-suspension-mount-ultimate.html 2 1 Share this post Link to post Share on other sites
