Hi, you can select the size required in the little drop down box on the manual screen marked "resolution". Here you have 3 choices, and the last one is large(print).
hope this helps
If you only see small then it means you are not logged into the main site (is your name in the top hand corner?) If not log in and then try again
cheers
Chris
