Sign in to follow this
Hello
I just purchased my first RC car which is the Quick Drive 2001 Subaru 1:10 scale . I was wondering if I could chasis swap it to a better performing chassi with minimal hassle. I want to use this car on the dirt in more rally conditions with jumps. Anything helps thanks in advance
Welcome, and yes you can.
The QD Subaru shell is the same track width and wheelbase as most 1/10 scale touring cars so the wheels will line up with the arches, and the front two screw holes for attaching it to the QD chassis line up with standard Tamiya body post locations. Not sure about the rear ones - when I did this it was with a QD Focus which uses different rear mounts - but I suspect they'll line up too.
Sounds like you are just buying another RC car. Why complicate things?
I bought it because it’s my car in real life. I have a 03 Subaru wrx. I thought it would be cool to drive a mini version of it.
3 hours ago, alvinlwh said:
Do you want to build or just want to pop the body and battery on and drive
I would like to just pop the shell to a new chassi with all the electronics to save the hassle. But I also don’t want to break the bank. I want to stay budget friendly.(if that’s even an option)
Will the touring cars be good to use on dirt tracks with twist and turns and jumps ?
It depends on which chassis you choose. Some like the XV-01 and XV-02 are designed for rally use and would be very good at this. Others designed for multipurpose use such as the TT-02 would do a reasonable job but are not optimized for it, but then they are a lot more affordable. Then you also get purpose-designed on-road race chassis that would not be much good that all off-road.
This. Depends of course on whether you want to get a little more into this but my TT-02, which is very much on a budget, requires a bit of tinkering and research and a few different parts to make it work on rally terrain. I also have an XV-01 which does it out of the box really well. Even with the tinkering the TT-02 is cheaper, but in the end it might not be by all that much and if it was to get near the XV in performance or toughness (mine won't) it'd cost more. I'm not saying splash out on an XV-01. My TT-02 is loads of fun. Just eyes open and all that.
NB, if you just want to drive it, other makes might give better bang for buck. Tamiya is a little more about the building, tinkering etc than many others.
23 hours ago, alvinlwh said:
require some level of building and electronics, unless you buy a second hand ready built with all the required bits already done
I was also wondering this is, well if it would just be cheaper for me to build the tt02 kit on my own and supply the needed plastic replacements for rally and figure out the electronics on my own. Or just find and buy a prebuilt tt02 kit with all the bits and supply the electronics on my own.
There are also plenty of second hand TT02s on eBay with electronics and hop ups that have either never been run or not run very much. Might be cheaper.
Thank you ima start looking tomorrow in the morning see if I can’t find any
1 hour ago, alvinlwh said:
And location too as prices can vary wildly between countries.
1 hour ago, Kpowell911 said:
First of all. Whats your budget?
I’m thinking $150 but I don’t really wanna go over $200 and I live in the USA
2 hours ago, alvinlwh said:
For that money, you can probably only get a basic TT-02.
https://www.towerhobbies.com/search?q=Tt-02&prefn1=discontinued&prefv1=false&start=0&sz=24&return=true
Add in the radio set, servo, maybe ESC (not sure if USA kits come with it or not), you will be looking at USD200. That is not even including the "essential big 3" upgrades.
Well I found these online for a XV-01 over my price a little but I’m willing to get these if they are better out of the box than TT-02. Would spending just a little more be substantially better
https://www.amazon.com/Tamiya-America-Lancia-Integrale-TAM58569/dp/B00CI064VE
https://www.rcmart.com/tamiya-1-10-xv-01-subaru-impreza-wrx-sti-ep-58528-00035267
The XV-01 is no doubt way much better than a TT-02 out of the box. Incomparable.
On 4/12/2023 at 11:36 AM, alvinlwh said:
Whatever your choice, just remember you have to add ESC, radio gear and servo too.
I think I have decided. I’ll save up to get a XV-01 do you have any recommendations with the electronics to use for it ?
You see, this is how RC gets you.
You started with a QD, then thought about a TT02 and before you know it, you're buying a XV01! It's like a drug.
I only bought my first proper RC in September, I've now got 6 kits/cars (only 3 finished, 2 were second hand).
