Evening all,
I’m downsizing to focus on things I’ll actually get time to build when I finally retire.
Some NIB kits will follow but (for now) I’m clearing out the vintage RC sets, batteries, chargers, tools and hop ups I’d carefully assembled to build the best of each.
Most are NIB - with the odd mint / used imported from Japan. Some are now incredibly rare.
There’s a long list below - which will go on eBay 1900 GMT on Sun eve unless I can help anyone out here ?
To be clear, I won’t reply to any new, low ball opportunists - you’ll be blocked and noted - but will happily help genuine / long standing members who know the value of what’s on offer / and how much it took to cover its cost.
Please PM me before the eBay listing starts if any interest 👍
Thanks in advance,
SC
Vintage Tamiya Batteries / Chargers
Tamiya 6v Battery 5502
Tamiya 6v Battery + Charger 5501
Tamiya 6v Quick Charger 5506
Tamiya 7.2v Quick Charger 5510 SOLD
Tamiya 1700SCRC + Charger SOLD
Tamiya 6v 4000 mAh Battery SOLD
Vintage Futaba RC Sets
Futaba Ripmax FP 2GS / FD-33 SOLD
Futaba Attack FP-2NBR SOLD
Futaba Attack FP-2NL / FP-S28 SOLD
Futaba 4YWD SOLD
Vintage Tamiya RC Sets
Tamiya RC AdSpec Plus Set (TX / CPR 160F / TPS 148) 45014 1 SOLD
Tamiya Finespec Set (TX / RX / TEU 105BK /  Servo / Battery / Charger) 45053 SOLD
Vintage Tamiya TRF Tool Sets
Tamiya TRF Tool Set (red / full) 49292 2002 SOLD
Tamiya TRF Tool Set (blue / full) 49267 SOLD
Tamiya KTC Limited Edition Tool Set 67037
Vintage Tamiya TRF Stands, Setting Boards & Towel
Tamiya Limited Edition Setting Board (red) 49290 SOLD
Tamiya Limited Edition Maintenance Stand (blue) 49224 SOLD
Tamiya TRF RC Car Maintenance Stand (blue) 42371 SOLD
Tamiya Motor Case 53634 SOLD
Tamiya Hop Ups
Chassis
Tamiya CS FRP Chassis 5123
Tamiya RM01 Carbon Suspension Arm 54461 SOLD
Tamiya RM01 Suspension Arm (F) 1481 SOLD
MaxSpeed TA02SW Carbon Fibre Chassis + Damper Tower Set (Porsche 934 / 230mm wb)  SOLD
Motors
Tamiya Gear Case & Motor Set RS 540 Countach / Porsche 936 1072 SOLD
Tamiya RS 540SD Sprint Motor 1136
Tamiya RS 540SD Endurance Motor 5200 SOLD
Tamiya FL Tuned Motor (30t) 54392 SOLD
Tamiya 18T, 20T, 22T & 24T Pinion Gear 5090 / 5175 SOLD
Tamiya 18T, 20T, 22T & 24T Pinion Gear 139 SOLD
ESC / Electrics
Tamiya Volac BL2 Brushless ESC 42144 SOLD
Tamiya TEU-302BK ESC 45028 SOLD
Tamiya Circuit Breaker 5105
Tamiya Futaba BEC Type A 250
Tamiya Flat Wound Resistor 5218 x2
Drivetrain
Tamiya Hollow Carbon Gear Shaft Set 53164 SOLD
Tamiya Skyline Speed Tuned Gear Set 51127 SOLD
Tamiya One Way Front Differential 53200 SOLD
Tamiya 936 Differential Bearings 5036
Tamiya 850 Ball Bearing Set 1073 SOLD
Tamiya Differential Ball Bearing Set 5248
Tamiya TA03 Ball Bearing Set 53265 SOLD
Tamiya RC 4x4 Vehicle Slipper Clutch Set 54412 SOLD
Steering
Tamiya Special Steering Set 5079 SOLD
Tamiya Ball Link & Adjuster Set 5068
Tamiya Special Rod End Set 5144
Tamiya Hi Torque Servo Saver Set 51000
Tamiya Aluminium Horn for HT Servo Saver (blue) 54121 SOLD
Tamiya Aluminium Servo Stays (blue) 49092 SOLD
Tamiya Aluminium Servo Stays (silver) 53596 SOLD
Tamiya Aluminium Servo Step Screw (blue) 54862 SOLD
Tamiya Aluminium King Pins (blue) 49068 SOLD
Tamiya Aluminium King Pins (silver) 53157 SOLD
JazRider TT02 Aluminium Steering Assembly (silver) SOLD
Suspension / Stabilisers
Tamiya Stainless Steel Suspension Shaft Set 53098
Tamiya 4WD Touring & Rally Car Rear Stabiliser Set TA02 53189 SOLD
Tamiya TA04 Racing Stabiliser Set 53676
Tamiya Aluminium 3 x 23mm Turnbuckles (blue) 54248  SOLD
Tamiya Aluminium 3 x 23mm Turnbuckles (titanium) 53526 SOLD
Tamiya Aluminium 5mm Aluminium Ball Nuts x10 (blue) 53640 SOLD
Tamiya Aluminium 5mm Ball Connectors x10 (blue) 53642 SOLD
Tamiya Aluminium 5mm Ball Connectors x10 (gold) 50592 SOLD
Tamiya 3x18mm Aluminium Turnbuckles (blue) x6 54247
Tamiya 3x18mm Turnbuckles (titanium) 53525 SOLD
Tamiya 5mm Low Friction Adjusters 54489  SOLD
TamTech Gear GB01 Reinforced Suspension Shaft Set 40506
Dampers
Tamiya Super Low Friction Dampers (blue)  49099 SOLD
Tamiya TA03 Super Low Friction Damper Set (gold) 53280 SOLD
Tamiya TA03 Super Low Friction Damper Set (black) 49089 SOLD
Tamiya Aluminium Damper Retainers (blue) 54776  SOLD
Tamiya Touring Car On Road Spring Set (white) 47447 SOLD
Tamiya TRF Damper Springs (black) 42168 SOLD
Tamiya 5.5mm Aluminium Spacer Set 53539 SOLD
Tamiya Damper Oils - S / M / H - 53025 / 53026 / 53027 SOLD
Tyres / Wheels
Tamiya Diplo Tyre Set 1075 SOLD
Tamiya Sponge Tyres (F +R) 55 / 57 SOLD
Tamiya Road Wizard Tyre Set (F) 5277 SOLD
Tamiya Super Grip Radial Tyres (F) 53214
Tamiya Aluminium 4mm Anodised Wheel Nuts (gold) 53161 SOLD
Tamiya Pin Type Wheel Adapter 53056 SOLD
Tamiya TamTech Gear GT-01 Mesh Wheels 40145 (F) / (R) 40555 SOLD
Tamiya TamTech Gear GT01 935 Dish Wheels
Tamiya Toyota Bruiser / Mountain Rider 9000359 B Parts (Wheel Bag) SOLD
Decals / Drivers
Tamiya Porsche 956 Racing Sticker Set (Canon / IKEI / Newman) 5222
Tamiya Group C Cockpit  Set 50460
Tamiya Touring Car Cockpit Set 54157
Tamiya TamTech Gear Porsche 934 Vaillant Wing Parts Set SOLD
Screws
TamTech Gear GT01 Titanium Screw Set 40550
  • 2 months later...
