ploots 185 Posted May 22, 2023 Hi all I'm just wondering if re re parts fits a mk1/2 srb, mines from 1984 and I still enjoy using it but one of my alloy front arms broke probably through brittleness around the fixing, luckily I have some spares but I might need some more as another is beginning to crack, so would re re front arms fit mine Thanks for any info Share this post Link to post Share on other sites
Dadio 126 Posted May 22, 2023 They fit but you need to change as a set , the angle is slightly different and by changing just one you'd end up with either massive positive or negative camber , also the white ball sockets are different and the ball studs for the steering knuckle are bigger , so in short it's 4 arms , new set of white plastic ball sockets and 4 new ball studs to convert the original to re re , worse than that the modern arms are far more chunky and not so nice looking however you would be future proofing the car so ...... Yes you can but it's more than you might want to change and it ends up uglier . 1 Share this post Link to post Share on other sites
ploots 185 Posted May 22, 2023 Thanks for the reply I thought it wouldn't be as simple as changing 1 arm I might look for some originals before I go down the re re route Share this post Link to post Share on other sites
Grumpy pants 4369 Posted May 22, 2023 The parts are all readily available on eBay, there are a number of Tamiya breakers. Well worth posting a wanted add on TC as well - with a picture of the part you need. Share this post Link to post Share on other sites
SuperChamp82 743 Posted May 26, 2023 There were 3 subtle differences in early / mid / late vintage SRB front arms from memory The re re equivalent can therefore be fettled to fit as @Dadio suggests but the materials, geometry and stress points are different So you’ll eventually end up transferring load to other parts of the vintage chassis - like the shock towers or hubs - that it was never meant to bear and which are even harder to find / replace The honest truth is Tamiya deliberately engineered things to break back then Not to sell hop ups - they were pretty much an afterthought until the early 80s - but simply to protect more expensive / harder to replace things from breaking and interrupting run time Example - wrapping cable ties around similar front arms was recommended in SuperChamp Result - hardly any slop and much better front end grip Outcome - the arms either snapped every other race or the ball sockets popped out every hard corner 🙄 My recommendation is you keep everything stock - buying vintage bits from eBay as @Grumpy pants suggests 👍 2 Share this post Link to post Share on other sites
