Sign in to follow this
OldSchoolRC1
Driving them all - 2023 resolution
I made a resolution to myself to get out of my rut and drive every trail truck I have at least once this year. I have 2 or three that are my "Go Tos" and the rest just sit. Shame!!
So to that end, I've been rotating around with various trail trucks each weekend. So far I've run:
Axial UMG
Traxxas  "Trail" Telluride
Element Sport IFS
Traxxas "Crawler" Telluride
Element Enduro
C-Maxx
Axial SCX10 III JLU
And many more to go...  I'll spare you all the non Tamiya's (Glad to post a pic of anything if anyone is interested) but anytime I get out anything Tamiya based, I'll update with some pics.
This weekend was sunny, mid 70's and I had sunday morning free...that means trail time!! Went into the Wayback machine and dug out 2 of my 4 CR01's for a little playtime. Ran into a lot of other guys out and about in the woods, not a single one of them even knew Tamiya made a crawler.. :)
First off, by OG CR01 build from 2009, heavily, heavily modified over the years and still running strong. Currently has Holmes/1080 power and a recently installed StealthX to give it a bit of OD.
Honestly, this is one of my best crawlers. It's a bit of a belly dragger, but nothing a blip of the throttle won't cure. I swapped over from the Losi Claws to the Carvers just for looks really. The tires are showing their age and aren't nearly as sticky as modern rubber (should have left the claws on, they are still excellent tires) but it got around just fine. Very stable, and climbs like a goat.
4WS is a must for these trucks since no one makes CVD's that I've ever found... with dogbones in the axles, steering is terrible. With all 4 wheels turning though, it's not bad at all. Plus, it's fun on the trail working that rear steering....I have yet to master it. :)
Put a battery through the Bug, than switched over to this piece. I picked this up from a friend when he left the hobby (still temporary I hope) and built it up OS style. Swapped to a lighter home cut chassis with standard shocks, but left it mostly intact driveline-wise.
Tires make a huge difference... the TSL's were up to the task today. The suspension is pretty soft, but raw grip got me mostly where I wanted to go. This one uses 4ws same as the bug and it's needed for sure. It has a shorter WB, so it was slightly more maneuverable.
This one is also kind of a belly dragger. The TVP chassis is somewhat tall, so it hangs down quite a bit. Just had to keep it in mind.
Something growled at me from this hole...took the pic and ran. I had the scene from Elf in mind where he tried to pet the raccoon. badword no, I'm out!
Only carnage of the day - took a tumble off a rock and landed right on the rear wheel. Popped out the servo! Guess I need 2 screws here... :) A few moments wrenching and I was back in action.
  • Like 11
Nice pictures. It looks like a great spot for trailing and crawler.
You really got an impressive number of trail trucks. 👍
Just getting started - I've got a quite a ways to go....
Neither of the CR-01s you have posted could be called stock..I'm curious - have either the Elements or the SCX10III been adapted much?
14 hours ago, Badcrumble said:
Neither of the Car-01s you have posted could be called stick..I'm curious - have either the Elements or the SCX10III been adapted much?
Definitely not stock. I don't think anything I have stays stock for long - I like to tinker. The other two are pretty modified as well, one with a lot of custom tube work. Pics to come!
The 10III doesn't have much - just some SSD brass at all 4 corners, front OD and a few body mods. Not overly impressed, it didn't do well crawling, the stock suspension is way too soft. Looks nice though.
IFS Element - mostly bolt ons and a Traxxas Sport body
Solid axle Enduro - again, lots of bolt ons but nothing wild. Doesn't need it really :
My Gatekeeper is running an Ecto body, I haven't run it yet. It's on the list for trail time!
Nice to see some more of your fleet and get your impressions on them. You've got some great trucks! Looking forward to seeing your next adventures.
I love the Rock Socker, I'd add one to the fleet if I see one come up for cheap. I think it's the best looking body they dropped on the CR01 chassis.
