Hi,
Hubs assembled as in manual with additional shims and of course bearings ( Tamiya).
As you can see, there is a lot of play. As you can imagine, adjusting suspension does not make too much sense with so wobbly wheels. It is the same on all four.
Is it also so wobbly with metal drive cups?
The problem doesn't look like it's the driveshafts, moreso the drive cup wiggles around in the hub.
Unless if it wobbles like crazy in motion, I wouldn't worry about it. Some day I should show you the play/wobble on my Frog!
