I'll put it in this forum, although it really isn't Tamiya ...
... but what do you use for charging the Axial SCX24 Lipos? And while we're at it, doing off-topic stuff ... what about the WLtoys (it's a 144001)? :)
I have a few of those tiny toy sized LiPo's and they came with their own USB based chargers.. so I use that.   But the same principle applies..   if only 1000mAh, just use 1A to charge.
Thanks fellows! The reason I ask is that I've heard that the Axial charger isn't "good enough" (YT wisdom), but I'll use it for a bit and see.
  • 4 weeks later...
To answer my own question ... :D ... I found a Spektrum IC3 to JST PH2.0 adapter cable that works (and then you obviously need to plug that into a charger). Perhaps that helps someone in the future.
