Blissard
WTB: Wild Willy gearbox bushings
I am interested in purchasing the bushing parts shown in the image. I acquired this gearbox long time ago but recently noticed that it is missing the circled pieces, causing the small gear to be loose like sleeve of a wizard.
934679223_Screenshot2023-09-27at21-24-27https__www.tamiyaclub_com.png.f512b67c67b43f0c8d10b192f9d517a0.png
The one I have has these small metal bushings that don't seem to serve any purpose. It appears to have been assembled incorrectly.
There are a few OLD threads on this, but the one below suggests the H2 bronze bushing can be replaced with a 5x8x2.5 flanged bearing.
On 11/17/2011 at 5:24 AM, waterbok said:
this should fit the H9 3x7x3
H1 5x11x4
and this for the flanged H2 5x8x2.5 Flanged
Thank you for the reply! I have just noticed that there's one H2 Flanged on the main shaft so I tried it on the missing place and it won't fit. I've noticed the following problems;
-Dimensions of the H2 I have seem to be slightly different than the flanged bearing on the link, but it fits the clutch gear perfectly.
-The G7 shaft I have is much smaller in diameter compared to H2 center bore but the shaft fits the metal plate and housing perfectly.
- The H2 won't fit inside the small gear.
- Neither the H2 nor the small gear seem to fit between clutchgear and motor.
Maybe the gearbox I have is from another kit ?
