After the Drum brake for Tamiya semi, a few gens of upgrade of my disc brake designs(I will post them up in these days), and the latest version is done.
Here's the finished pic:
image.thumb.png.35de5bd2255572f73d12b45116a542c2.pngimage.png.63bb2861a2dd945600243755a7d4f01e.png
and the road test video(I'm new to this forum, not sure if I shared correctly)
https://youtu.be/Us90L_eQiQg?si=UFM6fNTR_ckeXYAJ
Some designing and building process pics:
 The front space is very limited to fit the caliper and the mountings.
2 servos mount on the rear, 1for front, 1 for the rear, and the rear braking servo can be controlled independently to act like the handbrake. And that's the reason I choose XV02 chassis, it can be upgraded the central-diff.   The lever on the servo horn is to balance the pulling force between 2 wheels.
image.png.c91896d66e761ac3df56847e5ba593b0.pngimage.png.d5fcf4941a1867db9deb4486e2e47fb3.png
the motor cover is for scure the "heat pipes" . Because the XV02 has the dust cover on the chassis may reduce the motor's cooling efficiency, so I designed the heat pipe colling system, and move the heat sink to the front.
During in the test, the temp outside is 20℃, after 15 mins running,  the sensor on the motor cover indacated the temperature is 37, and when the car stopped, the temperature went up to 39 in less then 1 min, because the stopped car can't let the air run thrugh the heat sink.  And also means that this cooling system is very efficent.
In fact there are also 2 cooling fans behind the heat sink , but the winter is comming, and I'm lazy, so I didn't connect it to the power supply.
image.png.788f27fd5c9fbd6300c54cd406229744.pngimage.png.66d58d7fdb804058bcdbbb8a440dd8b6.pngimage.png.ba313a6da9cc080086b2f35da7e45930.png
Finally try to add some details. (not very good at the paint job, try to do it better next time)
  • Like 11
  • Thanks 2
Nice job, needs some LED's in there somewhere?. Sorry, couldn't remove unwanted pics in the quote.
It's always great to see engineering brought into the hobby. Cooling the motor is a great idea, what material did you use for the part that attaches to the motor? Aluminum or copper would be best.
Regarding the disc-brakes, how is their performance? DC motor braking is not particularly strong, I suspect that the disc-brakes would greatly improve the stopping distance by a large margin.
Try using Tamiya's M2 tires. This rubber compound makes amazing squealing sounds when cornering, similar to real road-cars, and I anticipate that when using your disc-brakes it would create an incredible experience.
Yes the motor  cooling cover is aluminum (3D printed);  and the braking force is iedal which all wheels can be locked on the high grip roads.
Thx for the tire advice and I'll try that.
8 hours ago, Gebbly said:
Actual working disc brakes?! Amazing!
How do you control the brakes from the transmitter?
Thanks, the brake servos are connected to the 3rd and 4th channel and mix-controlled with the throttle channel, then choose another botton to control the handbrake servo.
Holy Moly! Excellent work!👍🏻
