Thinking of buying a Hilux Highlift. Used to have a Ford 350 over 12 years ago which I always regretted selling. I remember wheels and tires were horrible. Are there any suggested tires and wheel sets that do not require you to modify the body and bolt right on? Thanks!
The wheels that come with the kit are far too small for my taste.  I fitted rc4wd 1.55 white 8 spokes to mine with 114mm tires.  I've also got some Injora wheels of the same design which are as good quality but cheaper.
Wow that looks great!
@davidwj95 also thinking of using my old Spektrum DX3e with 3rd channel switch to change gears instead of a twin stick remote. The DX3E's switch has adjustable endpoints so I think it should work.
Let us know if it works OK.  I use an old futaba 4 channel stick controller with a gate on the left stick to control throttle and gear change.  It's the only car I still use sticks on so I'd be interested to hear how well a 3 channel pistol grip controller works.
  • 5 months later...
I have seen listings online for adding bruiser adapters to these to add aftermarket rims/tires. Did you need to do that?
