has any one tried the 39mm Drive Shafts (Tamiya part number #53505 or OP-505) instead of the 37mm that are originally supplied with the kit?  (found this mod on a Japanize youtube chanel, from what I "can" understand these 2mm allows the shaft to remain in place even at full extension of the suspension)
Hi, I am using the 39mm in the front only.
I've had good experiences, both with the kit ones and with the double cardans. In both cases, the 39mm fit very well. In the rear they seemed to be a bit too long, so I stuck with the 37mm.
