1 hour ago, Frog Jumper said:
Sorry to hijack your thread but if you happen to have an extra set of rear axles for a SBF/KBF/BD, I am in the market…
iirc, the BD uses the Blitzer Beetle diff design, so does it also use the same outdrive cups and drive shafts?
@Sillyoldfox, if you now have the parts, could you measure a BD drive shaft end to end in mm? Might not be the same as the Blitzer though, due to the BD being a Monster Truck with different geometry .
https://tamiyabase.com/index.php?option=com_joodb&view=article&joobase=10&id=2079&Itemid=775
Similar but slightly different???  (Blitzer = 12595039, Bushy D = 12595082)
I wonder if they measure up the same, but somehow have different part numbers???
Terry
The Blitzer rere drive shafts measure in at 77mm, so if we can get a BD measurement from @Sillyoldfox when they arrive, then we might be onto a winner here @Frog Jumper mate👍
I checked the King Blackfoot as well, and that has 70mm drive shafts, but I think the arms and hubs are quite different on that truck when compared to the BD.
 Thanks for the info but im looking for the rear axles/cups, not the dogbone/shafts.
Oh I see, I don't think I've ever heard anyone call the outdrive cups 'axles' before. I reckon you'll have more chance of the BD cups being the same as the Blitzer Beetle anyway, due it sharing the same diff design, that's iirc, I may be wrong there.
They're referred to as axles in the build manual (bush devil) as per the image.
Super Blackfoot is the only cross reference I can find, King Blackfoot may be the same, but the item reference is different.
Not sure where OP is based, but THIS seller on eBay ships worldwide.
Ah I see!! Gotcha now😉👍
