I have made a bit of a mess cutting out the body in that there a lot of jagged cuts as i can't cut in a straight line. To tidy this up, would sanding the cut edges sort this out, if so which grit/grade of sandpaper would you recommend or is there a better way to sort it out?. Cheers
Yep, sanding will sort it.  I use some wet and dry I have lying around, not sure of the exact grade but it's fairly fine stuff.  I guess the grade you'll need will depend how badly jagged it is?
Do you use scissors or knife to cut?
