Hi All
i have just got this R6GS, paired with a R7FG receiver, I have paired and installed(see photos), I have a solid green led and signal bard on the transmitter, but nothing on the car works, no steering servo or motor activation, I have tried 3 receivers and all do the same, can anyone help?
Did you bind all three receivers properly? There's a small hole and a button inside at the side of the RX. Press and hold that button using a small 1.5mm hex screwdriver (or anything similar in size) when turning the ESC and the TX on. That should quickly do it.
Here's a quick guide.
I have two RC4GS and an RC6GS of my friend. All were very easy to bind and set up.
