burakol 463 Posted March 16, 2024 Anyone knows the parts number for the mini cva springs? I am looking for a few more if these to use for my drift cars as they are soft but I could not locate the part number to search. Thanks. 1 Share this post Link to post Share on other sites
Kowalski86 5128 Posted March 16, 2024 If it helps, the springs in 54465 are the same rate as far as I can tell, just a different color. Share this post Link to post Share on other sites
burakol 463 Posted March 16, 2024 5 minutes ago, Kowalski86 said: If it helps, the springs in 54465 are the same rate as far as I can tell, just a different color. What I’m having a hard time is finding the springs alone. I wonder if the springs has its own part number? do yoo know if the xv01 springs are same length as well? Looking for something around 30mm Share this post Link to post Share on other sites
SlideWRX 1124 Posted March 16, 2024 which CVA mini springs? if you are looking for something softer/stiffer, here is a spreadsheet put together a while ago: find the spring length you want and go from there. 2 Share this post Link to post Share on other sites
Pylon80 4366 Posted March 16, 2024 4 hours ago, burakol said: Anyone knows the parts number for the mini cva springs? I am looking for a few more if these to use for my drift cars as they are soft but I could not locate the part number to search. Thanks. Are you referring to the Super Mini CVA's set for the TT-02? The short and very soft black springs with a yellow dot? I would be interested if someone finds these separately 👍 Share this post Link to post Share on other sites
burakol 463 Posted March 16, 2024 2 hours ago, Pylon80 said: Are you referring to the Super Mini CVA's set for the TT-02? The short and very soft black springs with a yellow dot? I would be interested if someone finds these separately 👍 not the super mini… just the mini. I have the super mini and the red dot springs that came is not as soft as the longer silver springs that came with the mini cva set. Share this post Link to post Share on other sites
ThunderDragonCy 9196 Posted March 17, 2024 According to the manual parts list on the Desert Gator (the only one i could find with stock cva mini front shocks) it uses 9805484 as the front spring. I suspect this is what you are after, or very close. 1 Share this post Link to post Share on other sites
