Help me plss im looking for a spur gear and pinion gear for my tt02 if can 34+ pinion gear and 50 lower spur gear. Im looking for high speed gears. If can please give me amazon links. Also i have a high speed adapter from tamiya already soo please helppppppp
Amazon doesn't have anything decent. For smaller than stock gears you need to switch from the tamiya metric 0.6mod pitch gear teeth to 48dp imperial size. So long as both pinion and spur are 48dl they will mesh.
What country are you in? If uk, go to RW Racing.
Spurs https://rwracing.co.uk/shop/ols/products/rw-standard-touring-car-spurs
pinion
https://rwracing.co.uk/shop/ols/products/cnc-steel-pinions-324864dp
That also requires adjustable motor mount to set-up proper mesh
Although 48p can work with the original mount, the adjustable mount provides more options and precision.
pinion
I live in Indonesia😭💀
pinion
What does mesh means? 😁😅
It means how the teeth of the gear fit together.
Also whats the differnce between 48dp and 68?
48dp is bigger teeth than 64dp. They do not work together.
I have tried looking on amazon but i can't find anything. Can you find a hobby store that sells touring cars?
I can but im not sure if they sells tho i might need to check em
It's size of teeth (and 68T, marked on TT-02's spur means number of teeth). Tamiya uses metric 0.6mm profile on TT-02, 48p is equivalent of 0.53mm - the lower number means finer teeth. A 48p equivalent of TT-02's m0.6 68T gear will have around 77 teeth.
One does not need to use the YR adjustable mount necessarily. You can use an online gear calculator to find a combination of spur and pinion in 48p or in 64p that will fall onto the same motor mount holes as the original 0.6M part it replaces:
https://evolventdesign.com/pages/center-distance-calc
For example, if you want to use the holes 'A' or '16' of the mount, you are replacing the equivalent of 70t spur and 16t pinion in 0.6M. Distance is 25.80mm. Final Drive Ratio is 11.4 which is very slow!
In 64p (or 1/64in module), you could use 94t spur and 36t pinion which comes out to the exact same distance of 25.80mm, and a much lower (faster) FDR of 6.8.
You could do the same calculation with the other holes of the mount and get much lower FDR's (much faster). All of this without spending a dime on a different mount nor having to adjust the gear mesh.
On 3/20/2024 at 7:30 PM, alvinlwh said:
3Racing will post anywhere in the world and HK to ID will not cost a lot.
https://3racing.shop/collections/gear/gear
However, their smalles spur is 65T and I had never seen a 48p spur smaller than 60T. However a 65T spur with a 46T pinion will get you very close to the ratio you are looking for.
Alternative source for your part of the world will be Lazada or TB.
Alr i seee thank you ill take consider
U sure this tt02 can handle 46tooth pinion
I do have the yr mount alredy tho
So 3 racing is cheaper to id then rw?
Btw what version of the spur should i get to fit with my tamiya tt02 high speed gear adapter theres 2 kinds i see
Check the article I linked earlier. Without modifications, you can fit 35T/48p or  48T/64p. For larger pinions, you'd need to file part of the chassis.
Alr thank you so much, btw there's 2 version of the spur which one should i get?Or they're the same?
14 hours ago, alvinlwh said:
48p
Ver 1 goes from 65T - 96T
Ver 2 goes from 62T - 90T
64p
Ver 1 goes from 74T - 130T
Ver 2 goes from 87T - 118T
I usually go for Ver 1 as it is cheaper.
But both version do fit right?
