I've been following this guide to double check
https://www.youtube.com/watch?v=3_uhSpxgtmE
I build the first one fine the second pictured below ive struggled to tighten it up. Not sure what i may be doing wrong there at all.
I have stripped the first one i build successfully down as well but cannot see any difference at all. Ive also now managed to loose one of hte small washers from the working diff ive disassembled :(
1. These diffs are easy to strip. It's strong, coarse screw going into a soft aluminium diff plate. When they bottom out, you have to stop tightening them. So take it apart full and see if the screw will actually tighten in the diff half when the other parts are not mounted on it.
2. You need to find the missing washer otherwise the diff will slip all the time. These diffs don't work like other diffs, the spring washers set the tension, not the tightness of the screw.
Thanks for the advice, i iwll need to order a replacement kit for a washer i cant find it anywhere
update:  i've ordered a pack so will update if rebuild ok thanks for help
