So i was calibrating my rocket rc 120a esc and in the middle of the calibration i did something wrong and now when i want to recalibrate it i cant, the manual says when calibrating press the on/off button to continue thr next step but now when i do so the rc just shut off when i press the on off button so whenever i turn on the esc it blinks blue when it wants calibrating it does that but when i press the on off button to continue to it judt shuts off so now i need to find out how to reset my esc its a rocket rc 120a esc
Have you tried to start the process from the beginning? Don't know the ESC but when you follow the steps in the manual from the beginning you should  be able to complete the calibration.
I did and i got it calibrated, and are able to be programmed by program card butttt its still blinking blue😁😅
2 hours ago, TurnipJF said:
Is it working though?
I found out by a youtuber that said its normal if its blinking because it means ur not in turbo mode or boost mode unless if you use those modes then ur esc wont blink again so lmaoooo manual didnt tell me nun bout that soo ill info when it get to run and show jts top speed hehe thank you for ur support
Funnily enough, that's known as, racing "blinky"....
It let's the scrutineer know the esc has no timing settings, and set to basic for stock racing.
  • 3 months later...
Hi
I have   a problem  with calibrating the esp  can you send my  the  link because i don't find it  or  how you preform it ?
Regards Doron
