I want to replace my SS set up with SC parts.
I have the 3 steering rods, which other parts are required?
SC servo saver set?
B6-B7-A9-B7-EFF9-4-E8-A-835-F-2-C4-DD60-
SC servo saver & spring?
5-EAF0-A36-9003-4-E01-9-CCD-2322-A2-BEA9
Anything else?
Do these parts parts just swap like for like using the SS body post?
Thank you!
Hello,
You'll need the nut to load/pre-load the spring. Also you may have to modify the body-mount made of aluminum... Overall length and diameter are probably quite different. Do you have the Super Champ servo-mounts already? They differ from the Scorcher.
Some pictures if it can help.
Also, I know you didn't ask for it but... In my opinion, the Super Champ steering setup is no better than the Scorcher's one. To have mine working correctly, I had to modify it quite a bit. For a Scorcher, I think it is easier/more efficient to make a direct steering system, by the way. Please let me know if you'd like some pictures/explanations of what I did ;)
@Mouc-RC, thanks for the reply, really helpful.
At the moment I’ve got just the 3 rods, interesting to read it’s not an improvement though.
I’d be grateful for some pictures and an explanation of what you’ve done as well please 👍
Hello!
On my Fighting Buggy, here's what I've done:
- small servo, a bit inclined (if you don't incline a bit, you have some collisions between a full-size servo and the steering mechanism - yes, it is that bad)
- M3 steering rods + M3 ball ends (OG small ball ends pop-out often otherwise)
- elongated final drive horn on the save-servo, to have a real steering angle (made a small plate that moves backwards the ball ends)
To be done: move the pivot point backwards about 4mm (the small servo will help for this point): the steering is still asymmetrical, because the upper save-servo horn hits the aluminum bar when the rod is pushed forward (hence the notch in the bar - yes, it is that bad...)
Works not bad, keeps the original spirit, but that's a lot of modifications. I'd say that the only good point on the SC/Fighting Buggy steering is the save-servo, more precise that on a Scorcher one)
On my Brother's Scorcher, here's what I've done (following an idea seen on TamiyaClub by the way):
Small "home-made" plate that mounts directly in the radio-box and accepts a full-size servo. And then I used the original hardware to make the steering work in a simple way. A bit more sloppy than the solution above with a save-servo (because the radio-box is mounted on some rubber mounts), but honestly quite good enough for an SRB, I'd say :)
To be done on my brother's Scorcher, change ball-ends to 5mm/M3 diameter ones (sick & tired that they pop-out quite often).
Many years ago I designed a special front post to mount the SC saver to the SS chassis and vorrect height to mount the body which still allowed the adjuster nut to be adjusted . The stock SS post fouled the nut . Sadly I don't have any of the posts now . I think I still have a pic in my showroom .
