Hi, I've been looking through posts and had no luck, yet..
I have an original Wild Willy from 1984, that I restored, after spending 30+ years in neglect. I managed to obtain a Hump Pack battery several years ago from the UK, and it worked.  However, I was too scared to use it too much, then the next time I udsed it the battery was dead ( think I may have disposed of it). When I looked at the Ebay site again, they had no stock available. I've been unable to locate this recently.
I've seen a few posts about hacking the original case, which I think I may have disposed of.
So, What would be the best solution?
Is there a battery available somewhere, Or will I need to buy Sanyo/Panasonic 'C' type batteries?
Can you use a LiPo substitute? (I assume not)
If you’re going to run the WW, then recasing a new battery in the old case would be my 1st route.
If it is just for display purposes, then I would just clean up the original battery and leave it at that.
A quick search on eBay for ‘Tamiya Sand Scorcher battery’ brings up new hump back battery packs.
Overlander make custom battery packs. I used them to make a custom pack for me and their customer support was very good at responding. You could give them a shout and see if they could make an old hump back style battery.
As an example they made me a 7.2v 5000mAh NiMh with xt60 connector and it cost £30
In fact WheelspinModels is selling one of their batteries that looks like it could be humpback shaped. Would this fit?
Thank you. The Wheelspin looks perfect. :)
Hopefully freight isn't too much.
Thank you guys (especially Overlander). The battery arrived today. Well packaged and postage was reasonable.
38 minutes ago, Gebbly said:
Fingers crossed it fits and Willy is zipping around again soon :)
Any chance of a photo of the finished vehicle?
I've never painted it. I know I was missing crossbars, and bought new ones for WW2. I did upload original pics(somewhere), before I started restoring. The battery looks great. I have a new charger that is better than I had. Previous battery may have been with this charger.
I still have some original decals.
