Hello folks,
this is about my next project: re-building an used Fighting Buggy and modifying it lightly along the way. Disclaimer: I will waffle a bit in this one… :lol:
The background:
The missus has a brillant idea: we will go to De Haan in Belgium for a week in the coming winter. Sounds great, doesn’t it: a little holiday at the sea, some of those excellent Belgian beers,... And the rare possibility to run a RC car on the beach! But which one? My DT-02 in Rough Rider disguise? The Wild One BHM? Or even the BBX? All three would not look out of place in the sand, that is for sure. Nevertheless I will take the opportunity to build another car, set-up specifically for running on the beach! When thinking about beach-running a RC, instantly the SRB chassis cars come to one’s mind. The Sand Scorcher and the Rough Rider/Champ come with a watertight-kindish box for the electronics, which would be good for the intented purpose of this car. And I do find the SS and RR aesthetically more pleasing than the Super Champ/Fighting Buggy. Nevertheless the FB is something special, due to it’s quirky rear suspension. This had immediately fascinated me when I first saw it in the early eighties. So the FB it had to be! Yes, I know for some the FB is not really a SRB, but it does belong to the greater family, I think.
The base:
A lightly used one turned up online, which I was able to buy for a reasonable price. The standard of it's initial build had been mediocre at best (application of stickers, etc). Mechanically it seems to be okay, apart from leaking dampers, which is to be expected with these cars.
The build plan:
I will try to make this car well-suited for the harsh environment that the beach is: salt-walter and fine sand:
- Dismantle, clean and re-assemble on an alloy chassis
- Use stainless hardware where possible
- Stick with the spool and resist the urge to put in a diff
- Fit a watertight receiver, ESC and servo
- Paint the body (probably non box-art)
- Use plastic bushes for the wheels(?)
- Stick with the silver can, maybe a Torque Tuned
- Use a 15t steel pinion
- Fit paddle tires
The stickers had to go first.
IMG_20240923_204737021
Then the body got a light sanding in preparation for the new paintjob.
IMG_20240923_220135493
The axles were cleaned and re-built:
IMG_20240924_233125877
IMG_20241007_222649182
Very unique, those early designs! :)
I re-built the dampers, using clear o-rings and lots of green slime in the hope of getting them to stop leaking. For the rear damper I tried my best to get all air out of the hose! I even screwed it to a wall while doing so. :lol:
IMG_20241007_230056329
Then it all went together again, but this time on an alloy chassis.
IMG_20241008_225811386
Mount them upside down, trust me.
Enjoy 👍🏻
These are a great classic RC.
I run a 20t Kyosho brushed in mine to help push it along sand. It’s also worth plugging the holes where the motor wires go through the clear cover with a bit of foam or something to stop stuff getting in there, & I put a smear of grease on the mating surface of the clear spur cover to help seal that a bit to. I even smear grease on some of the inside edges of it so if something does get in it then sticks to the grease out the way rather than mashing up the gear teeth.
5 hours ago, Re-Bugged said:
Enjoy 👍🏻
Great tips about keeping the dirt out!
Currently I have put the original motor back in, but for the planned trip to the Belgian Beaches, a stronger motor would probably be a good idea. I do have a TT, a ST and a Kyosho G2X and need to decide which one to use.
When I took the gearbox apart, the counter gear showed some serious dental problems...:blink:
IMG_20241107_074101795~2
I replaced it with a new one. Only after that I learned about the possibility of replacing it with a cut-down driveshaft (13565002), which is probably a better solution.
  • 4 weeks later...
As the holidays are approaching fast, I need to finish the Beach Runner!
Chassis has been completed with electronics.
IMG_20241204_231037893_HDR IMG_20241204_231045813_HDR IMG_20241204_231056527_HDR
I have replaced the wheel bearings with plastic bushings and fitted paddle tires.
The body was painted on the last possible day (weather) in a hurry! I went for a matte and unexcited gray with only a few red accents in order to highlight all the alloy parts. No decals, too. This is very hard for me, I love stickers! The paint will need rectifying in spring as I had not masked the side panels properly... Doh!
IMG_20241204_231121856_HDR
The car looks like this now.
IMG_20241204_231323093_HDR~2
IMG_20241204_231344447_HDR~2
IMG_20241204_231424583_HDR~2
Only little jobs left to do: replace the original motor with a TT and give Ol' Copperface a cosmetic treatment! :lol:
IMG_20241204_212135450_HDR~2
The driver has been repainted and glued back in. So, for now, the Fighting Buggy is finished and ready for the beach. I did a short test drive on tarmac just to check if everything works. The car felt much faster than I had anticipated. You have to drive really carefully and make up your mind before entering a curve, etc. We'll see how it does on the Belgian shores in early January. I suspect it will need another re-build afterwards...
IMG_20241209_113801514_HDR~2
