Hypoxic
Toyota Yaris Rally Gazoo
Boom! There she is! (Song Boom by P.O.D - video lags but the song rules. This is the build theme song. Just look at the image and listen to the song: I never knew that a « KIT » like me….).
Begin the community Gazoo build.
I have the bearings and shims. Where to go from there? You decide.
Something I saw in advance. I don’t understand the text, but the images state enough.
This body is amazing! If I will not find Pre Painted version, I will probably go for it next year.
What is your plan for build? Any Hop Ups?
Community build. Up to you all. ;) Discuss and contemplate each phase. BTW, I’d like to make this a functional build, and not an all out ‘BLING’ build.
Ok. So I’ve been window shopping and, yeah, probably will add hop ups. There’s some really cool stuff out there and rally cars ARE high performance, tricked out vehicles, right? :)
I definitely recommend to buy:
- Oil shocks + TRF pistons
- Aluminium steering
- Aluminium rear uprights
- Metal suspensions balls
- Wheel Hexes with screws
- Ball bearings
- Aluminium motor mount
- Machine screws
List is much, much longer.
Unfortunately, at this point it will be more expensive than XV-01, which is much better and has all mentioned upgrades ( or equivalents) straight from the box.
TT-02 is great chassis, but if you want to upgrade it, you will do this only for fun, because it does not make sense from economical point of view.
How deep is your wallet?
Wrong.
It has been generally agreed that the limit is set at ~£250 for 2024.
24 minutes ago, alvinlwh said:
Wrong.
Real Rally Cars are very expensive, built using advanced technology. They look like "normal", because they have to be based on road cars.
Hang on, is this thread about building a real car or a RC car?
I am not sure if OP wrote about real cars or RC cars.
Maybe I put that out there wrong. I was trying to say that since real rally cars are high performance machines, my little plastic machine should reflect that, best I can. :D
So my first thought was correct!
How much do you want to spend on Hop Ups?
Looking at all of that right now. I see there’s a complete kit by Yeah Racing, but don’t think I need all of that. Maybe I’ll start with the obvious bits and slowly dig deeper as I learn the car. Then I can see the benefits of what I do and it’s more fun that way!
If anything that YR kit is more detrimental to performance than anything else. If I were to make a TT02 into a rally car, I'd grab the following:
1. Metal dogbones/cups for the back, universals up front. Combine this with the taller CVA eyelets and some trimming and you'll gain more ground clearance.
2. Chassis cover, waterproof servo/esc (the Hobbywing 1060 is waterproof).
3. Basic CVA shocks with single hole pistons.
4. Spare o rings or foam donuts to protect the bodyshell.
5. Low friction metal suspension balls, the stock ones will gradually wear out in dirt.
6. Leave the driveshaft and steering stock, a decent servo and a glued kit servo saver will give you acceptable steering. The stock driveshaft can take some serious power before warping.
7. If you want more speed, buy a pinion gear set and a slider motor mount.
Like the Tamiya 50519 shocks?
There are in fact two YR kits. CK-TT02 and TATT-S07. Getting both will gey you 8 dampers though.
I'd go with 54753 for shocks, that way you get four in a package for the same price instead of two.
These actually come with very soft springs which you will need for rallying.
I would use 3 hole pistons and 300 oil though, but let's not make it complex and costly just yet. They'll work great with the supplied oil.
1. Metal dogbones/cups for the back, universals up front. Combine this with the taller CVA eyelets and some trimming and you'll gain more ground clearance. (Ordered the dogbones but the cups are harder to find. Need to research the universals some require extra parts that I haven’t found)
2. Chassis cover, waterproof servo/esc (the Hobbywing 1060 is waterproof). (Ordered the Tamiya 22023 cover)
3. Basic CVA shocks with single hole pistons. (Ordered)
4. Spare o rings or foam donuts to protect the bodyshell. (Will fabricate)
5. Low friction metal suspension balls, the stock ones will gradually wear out in dirt. (Ordered)
6. Leave the driveshaft and steering stock, a decent servo and a glued kit servo saver will give you acceptable steering. The stock driveshaft can take some serious power before warping. (Looking for a decent servo saver)
7. If you want more speed, buy a pinion gear set and a slider motor mount. (Ordered motor mount)
Still under 100€. I think it’s a good start!
I picked up these off amazon. I thought the red would fit better with the shell.
Hmm, they are probably heavier, more expensive and do not provide any advantage over standard plastic parts. They also will wear faster. I am not sure if it was good choice.
Have you bought Ball Bearings?
Maybe. But I like them.
Some more parts arrived today. :)
The dog bones were ordered before I found the other parts. But they’ll be set aside for another (hers) build.
So, I’ve learned that the prop shaft bearings on the TT02 are just a little larger than the hub bearings. I thought I had excessive play in the prop shaft until I realised my error. You can see the gap (blue) from installing the smaller bearing. Lesson learned.
