trev82
Pen for detailing
Hey,
What pens do you recommend for hard body detailing, such as window frames, door handles, even work on driver figure.  Black and silver be the main options required
Thanks 😊
Posca or Gundam markers. Depending on if you want safe paint or toxic paint.
fwiw. you're probably better off buying a set of fine brushes, and using those little pots of acrylic paint (Tamiya, Humbrol etc) - not only will you get a more control with line width and paint volume, but you can also mix colours and adjust the thickness/viscocity of the paint with water - better for detailing fine moulded details.
Note if you plan to paint window frame and rubbers, use this trick - makes it very easy to get a sharp edge:
photo. mask the whole windscreen, then cut out the tape around the edge of the rubber with an x-acto knife...
photo. simply paint on your chosen finish (note Tamiya XF-85 'Rubber Black' is perfect for window surrounds to replicate actual rubber, rather than using plain satin or flat black) - and once dry, peel off the tape to reveal a sharp line.
Hope that helps!
