Hi folks, what do you use to sit your cars onto, if they are on the shelf? I want to step away from my current solution of using random boxes and pieces of wood...:lol: Had a look around but it seemed all quite expensive.
In addition to random boxes and pieces of wood I am using pieces of foam, old wheels and tyres. Nothing pre-made or professional in any way. 🙂
Most of my cars are on shelf brackets supported by twin-slot wall rails.  They're not cheap to start off, but once you compare to RC-specific wall-mount solutions then the price-per-car is not so bad at all.
Otherwise, I mostly upcycle other thing because RC-specific stands are just so darned expensive.  There's no price on that koswork stand, although it looks absolutely gorgeous - I'd love a couple of those in my workshop - my guess is they (like the Turtle Labs stands) are designed for the RC 'fluencers who really need that snappy, coordinated car display to sell their entertainment channels.
For clod-scale monster trucks, I use ice cream tubs.  I stick a label with the truck name on it and throw the spares in there
For touring cars and other things with flat-ish chassis - spreadable cheese tubs.  Perfect size to keep the wheels off the ground
Mid-size monsters and crawlers - larger dairy spread tubs can be used, although mostly I use my wall mounts for these
Rememeber - you can paint tubs so they aren't ugly.  I use satin black peelable paint, it sticks to everything, has good coverage, and the spreadable cheese pots no longer look like spreadable cheese pots but actually look pretty much like expensive RC car stands.
For my big rigs, I 3D-printed some rear axle stands that cup the diff housings (also fits TLT axles) but didn't get around to making a recess so they also fit the front beam axle.  That said, my big rigs are quite happy sitting directly on the shelf since the tyres are fairly solid.
my Tamiyas live in the garage, previous home owner lined the walls with peg board. I use 2 6 - 8” long hooks to hang them up. And a couple of smaller ones to mount the radios underneath.
I came to the conclusion that I like the idea of buying a stash of cheap storage containers of the right size and then painting them black or silver best. The stands available are just to expensive. With the money saved, I am gonna buy some useless hop-ups! :lol:
If it works, it works.
If you know anyone that does a lot of target shooting or trap shooting, many times they reload their own ammo to save money.   The little trays the primers come in can be used to make great RC display stands.  They're free, rather thin so you can stack them to make stands only as high as needed to get the wheels off the ground.
All I do is glue them together or sometimes screw them together, paint them flat black and glue a layer of some thin non-slip shelf liner or the such.   I probably have close to twenty around here for pretty much the cost of some cheap glue and a can of spray paint.   I also cut up some cheap felt pads I had laying around to keep the stands from scuffing up the shelves as I slide them around to dust......(if I ever find the time to do that :huh:)
1"x6" Styrofoam disks for the M, Touring, and Rally cars on a shelf unit in the hall. Radshape RC wall brackets for the buggies, which are surprisingly inexpensive from JK-RC.
Old cream cheese/sour cream containers, worn-out tires/wheels, foam blocks, whatever it takes to keep the tires from flat-spotting. I'm not much for "displays."
Great idea! I do know some guys who do target shooting. I will check with them.
I do use most of my cars, too. But some stay in the shelf of my office, so I can admire them during coffee breaks...:lol:
I bought a few of the metal ‘stands’ (I linked to above) to try. They ok and adjustable so can be used for different models / chassis heights as shown. To make them nicer it would be beneficial to glue some rubber to both sides to make it less ‘scratchy’ to use (but maybe I’m being a bit precious)
On 11/6/2024 at 9:19 PM, CoolHands said:
You can get these laser level stands fairly cheap around £3.40 with tax
Aliexpress 90 laser level
Thanks, I ordered some and they arrived today. They seem to work well, although I might use some sticky pads so that I don't knock them out of place.
Previously I could only get 2 cars (the Grasshopper & Lunchbox) on this shelf, as the shelf isn't deep enough for them to face the front without rolling off. The stands have allowed me to fit a 3rd model to the same shelf. :)
