skom25
Should Servo touch chassis?
Hi,
I want to use servo mounts like below:
Servo mounts are installed at two points which are around 2 mm above flat part of chassis.
In that case, servo will be in the air.
Is this fine?
Standard servo mounts are bit shorter and servo is little lower, but I am not sure if it touches chassis.
Some models are like that, it usually won’t be a problem.
I believe that the Tamiya ones are placed so the Servo is flush... because of the inherent flex of the soft nylon mounts. I  would still want flush mounting, like @Twinfan said, so you don't flex the chassis tub as much.
@Nicadraus what is you experience in this topic with XV-01?
I bought TRF 416 mounts #3454510 which are like that:
As comparison, this is RM-01 mount which is dedicated for XV-01:
They even have the same small "step" at bottom of mount. Only possible difference that can be between them, is that on RM-01 holes are bit lower, so servo can be mounted closer to chassis. However, I am not sure and it is not possible to measure this without parts in hands.
I can also use quite stiff self adhesive foam #54430 to close gap, so servo will not float.
Most race grade cars have floating servo mounts for a reason. Hack, even my relatively cheap 3R M4 has a floating servo mount.
There is absolutely no "problem" with the servo touching or not touching. You can proceed!
This is not what a "floating mount" means in modern TC by the way. Floating mounts attach to the chassis from one side to avoid the servo and its mount acting together as a chassis brace, that would change the chassis' flex characteristics on the servo side.
Now, since the picture you posted looks like the much loved but long since discontinued RM-01 mounts 😍 by all means share with us your source if you found a set!
As I wrote, I bought part #3454510. TRF 416 servo post.
Thank you!
Thank you!
That mount is the best looker 👌
If you are looking for similar mount, you can also try #54090. To be honest, they all look almost the same and I think that differences are minimal.
The one you bought as well as 54090 have been discontinued for almost 10 years now, having been depleted by TT-02 users after 2013 😟 so yours must have been a lucky find!
Seriously?
I just check from time to time, what interesting my LHS has in offer. There is a lot of interesting stuff, but I was pretty sure that mentioned parts are from more or less current catalogue.
Such a shame that we do not have international Ebay here. Maybe I am sleeping on money :D
I'm using the RM-01 mounts on my XV-01 (also in my FF-03 cars).
As seen below, I placed a 2mm carbon fiber plate which raised the servo. Works perfectly.
Th XV-01 doesn't require a floating servo mount. Servo is mounted sideways so floating the servo is pointless.  It is a race-worthy car.
Agreed.
Thank you!
In that case, I assume it is totally fine that servo will not touch chassis. I was bit worried that it will have negative impact on chassis durability, but probably I am overthinking this.
