I am curious if the Hornet can be run on a 2S Lipo?
The Hornet Evo kit comes with a Hobbywing Quicrun 1060 Brushed ESC which can be run on a 2S or 3S lipo battery (Think 3S would be overkill).
If you can run a 2S lipo, will a hardcase Lipo battery fit in the battery compartment? I have read that hardcase lipos are just slightly too long to fit in the battery compartment and again, I do not want to have to make any modifications.
Yes they can run on 2S lipo not a problem. Not too sure about hard case, but I can just get my 4000 2S stick pack style battery in. I did install a low profile servo to make that extra room for battery leads! Currently running 2S in my Evo and it is a lot of fun. 2S is about right for Tamiyas.
You brought up a point there.
I have not bought a servo yet.
Glad you mentioned the low profile servo before I went and bought a Lipo battery.
With a low profile servo, I can fit my battery in and gently bend the cables under and round to the connector. With a normal sized servo it would be a very tight fit I think.
23 minutes ago, ThunderDragonCy said:
Shorty lipo fit no problem at all. You just need some foam block to hold it in place.
100% That's what I did.20240918_183603.thumb.jpg.addd00bd43f97110c6a4e24a3ad70959.jpg
4 hours ago, Wooders28 said:
Never actually tried it in a Hornet, but these have fitted anywhere a 6s 7.2v Nicad/nimh have fitted.
https://www.modelsport.co.uk/product/core-rc-4000mahr-74v-30-60c-2s-lipo-388538
The price is right (About US$34.07) for the batteries.
Looks like they are not available in the US, as most of the google search results lists shops in the UK.
That 1060 will run 2s, but I strongly recommend ditching the stock molex/Tamiya connector if you go the LiPO route. Deans plugs seems to work best for Tamiyas with tight battery spaces.
I tried and failed to get a core RC battery to our side of the pond. But there are tons of other options. The "Gartpot" ones if you can pronounce the name without getting turned off:
GARTPOT 7.4V 4000mAh 50C 2S RC LiPo Battery Hardcase with Deans Plug for Tamiya TT01 RC Truck Car Losi Slash Buggy Team Associated (2 Packs) https://a.co/d/jbKvZFH
Or the Team Orion one ("Team Orion 2S 60C Ranger LiPo Battery (7.4V/3000mAh) T-Plug - ORI14311") are often used on Tamiya cars.
Both cheap options, I use the latter on the Group C which has a tight battery compartment especially lengthwise.
I believe CoreRC is a subsidiary of Schumacher, so that maybe the case.
My current NIMH battery has a deans connector on it, so I will have no issues getting deans on my LIPO and converting the one on the ESC to deans.
Thanks for the tips.
Will look into these options.
