For those of you that have built the Hornet Evo (or re-release).
Is the soft option damper oil that comes with the kit good enough for it's intended purpose?
Is there any reason I should look at going medium or hard?
2 hours ago, Kowalski86 said:
Hornets of all variations weight next to nothing, stiffer shock oil may work on pavement (and with a 5000mah NiMH brick), but I'd use what's in the kit.
Duly noted.
I was bored going through my originals and re-re's that are stock and ran them all around the basement one after the other.  I did almost accidentally throw the hornet into the air taking it off the shelf...
For the front shocks the soft oil is fine, the rear shocks are fine for on road use, but they do seem a bit soft when I drop the car. Some stiffer springs and single hole pistons or thicker oil in the shocks may help a bit, but I have not tried it yet. I run a shorty Lipo pack that is mostly up front, so tuning setups may vary.
